Electrical Wire in TowerElectrical
By Boondocker, Section Wind
Posted on Wed Feb 14, 2007 at 11:39:49 PM MST
Electrical
What type of wiring is best to run down the tower; no slip ring design?   So far the heaviest extension cord I've located has three 10 AWG wires.  It can handle the load of the machine I'm building.  However, losses are significant.  No. 6 Welding cable sounds like a good idea (flexible, UV and oil resistance) although pricy.
I'm starting to scourge around for some tower wire.   It appears to be a critical part of the system and should be considered when matching the blade to the alternator.
Thanks,
Boondocker
Electrical Wire in TowerElectrical | 4 comments (4 topical)
Re: Electrical Wire in TowerElectrical (3.00 / 0) (#1)
by wdyasq on Wed Feb 14, 2007 at 05:44:56 PM MST
Boondocker,
Many of us here failed to renew our clarvoyancy licenses. The government was going to require fingerprints and social security numbers - Imagine that!
So, if you would be so kind as to provide a few details ... maybe someone could help.
Re: Electrical Wire in TowerElectrical (3.00 / 0) (#2)
by Titantornado on Thu Feb 15, 2007 at 06:59:34 AM MST
Fine stranded wire (like welding cable) is best, but just use what you can get, (as long as it isn't solid wire) sized as big as you are willing to pay for.
Rod
Re: Electrical Wire in TowerElectrical (3.00 / 0) (#3)
by davewheeling on Thu Feb 15, 2007 at 09:54:04 AM MST
Try these 3 outfits on for size Boondocker.
Word is that Maney has some of the best welding cable prices.
http://www.maneywire.com/wire_cbl.htm
http://electrical.hardwarestore.com/14-48-sj-cord.aspx
http://www.westwayelectricshop.com/shop/Wire.html
Here's a site with some tips that many people have used.
http://www.tlgwindpower.com/tips.htm
Dave
Re: Electrical Wire in TowerElectrical (3.00 / 0) (#4)
by Boondocker on Thu Feb 15, 2007 at 04:02:07 PM MST
Thank you for the suggestions, and links.
The mill will be 3 phase rectified to a 24 volt battery bank, with an eight foot prop.  The distance from the alternator to battery is going to be approximately 100 feet.
Boondocker
  149 Scoop users have viewed this posting.
· Also by Boondocker
