Chopped fibreglass for staror/rotors
By Marco, Section Mechanical
Posted on Sun Mar 18, 2007 at 11:31:57 AM MST
idea.
I have had an idea for putting chopped fibreglass into the resin mixes for the stator and rotor.
Put sheets of the fibreglass material into a paper cross shreddder and you get a fine size of 'chopped' stuff'. Just to make things a bit quicker.
If someone has already posted this idea, then apologies for posting again.
Marco.
Chopped fibreglass for staror/rotors | 4 comments (4 topical)
Re: Chopped fibreglass for staror/rotors (3.00 / 0) (#1)
by Titantornado on Sun Mar 18, 2007 at 08:12:15 AM MST
Just don't get caught by whoever owns that shredder, else you may have your @$$ in a sling! You are aware that fiberglass mat is held together by an adhesive binder that is designed to break down in polyester and vinyl ester resins, yes?
Rod
Re: Chopped fibreglass for staror/rotors (3.00 / 0) (#4)
by la7qz on Tue Apr 03, 2007 at 04:57:53 PM MST
Hi
Epoxy suppliers will supply fibreglass mat without the adhesive binder, for use with epoxy. I don't know much about wind power, but I've done a lot of epoxy work on boats.
Owen
Re: Chopped fibreglass for staror/rotors (3.00 / 0) (#2)
by cdog on Sun Mar 18, 2007 at 08:34:10 AM MST
This is what I used in my stator, I'm not sure its proper, but I think i'ts along the lines of what you are thinking about. The site I found it on is called masepoxies.com. Under products click "fillers" and scroll down to "milled fibers".
I would have posted a link but I have no idea how to,lol.
Cdog.
Re: Chopped fibreglass for staror/rotors (3.00 / 0) (#3)
by gordon01639 on Sun Mar 18, 2007 at 09:07:54 AM MST
here is the link.
http://www.masepoxies.com/mas6.htm
Gordon....
  94 Scoop users have viewed this posting.
· Also by Marco
