| Friday I finally wired up my turbine using the 25 Amp bridge rectifier dumping power into an old dead 12 Volt motorcycle battery.
It took until today for the wind to come back so that I could try some measurements. First thing I did was measure the voltage of the battery. 11.2 Volts. T
hen I went to measure the current the turbine was putting out so I took the positive to the battery and disconnected it and ran it in to the multimeter on the red line plugged into the 10A port specifically for testing current up to 10 amps. The black com line then connected back to the battery where the rectifier used to connect.
I then waited for a good blast of wind. I never got any reading at all. It was always locked in at zero. so I switched over to the milliamp settings and even at the smallest 2 milliamp setting I got .000 amps. So I'm assuming I did something wrong.
A few hours later I checked and the voltage on the battery was up to 11.5 Volts so I'm assuming it was charging slowly.
How do I measure the current correctly? It could be my $10 multimeter sucks for this but I want to be sure. |
105 Scoop users have viewed this posting.
