Question for Hilltopgrange
By WindHarvester, Section Heat
Posted on Sat Mar 24, 2007 at 10:32:24 PM MST
Inquiry on your vegetable oil heating unit
Hi Russell,
In an earlier post you mentioned you heated your home and workshop with vegetable oil.
I was wondering if you would please explain your system in a little depth as it's something I've been studying for future use? It would be greatly appreciated.
I have googled the board and studied on other sites but as many different points of view I can get is always helpful.
Things I'm wondering are basicly your design(diy or purchased), used or unused oil, btu's and efficiency, and even a photo if it's not to much trouble?
If your too busy with other projects I totally understand.
The reason for a seperate post on the subject is because I didnt want to hijack another persons thread.
Have a great weekend!
Lonnie
Question for Hilltopgrange | 3 comments (3 topical)
Re: Question for Hilltopgrange (3.00 / 0) (#1)
by Hilltopgrange on Sat Mar 24, 2007 at 06:05:20 PM MST
Hi Lonny              it's no trouble, I was intending to do a post about it at some stage anyway but where do I start lol
I basically run my central heating for free and have been doing so since December; the burner itself is a commercial burner that will burn any type of oil you can lay your hands on. But the burner is bit expensive at just over £1000 GBP or about $2000 USD
The decision to buy the burner was arrived at after about 2 years of trying to make one or modify an existing oil fired burner... with some successes. The big snag with a lot of the homebrew designs is 1. Reliability and 2. Safety. I think I have tried them all from Babington burners to Mother earths design and few of my own as well but I wouldn't trust them to run unattended or on a timer. This system however works very well and has seen us through this winter at zero cost for fuel !
I live in a 400 year old farm house on an exposed hilltop, the house is built from granite field stone with walls over 2ft thick... so basically I live in a heatsink, you couldn't heat this house if it was on fire!. The house has oil fired central heating but to keep us at a comfortable 23C was costing a fortune in oil. A 1000 litre fill was costing £350 GBP and was only lasting about a month........ So something had to be done
The burner is made in Germany but I have seen similar units from the States for a lot less but import duty and shipping to UK was to expensive
 This link is where I got it
http://lechma.de/shop/product_info.php/info/p36_Universal-oil-burner.html/XTCsid/e13ff2eab86f50ee7ef acb6ce37e0c0a
At the moment would you believe my heating is running on beef lard from my local fish and chip shop (fries) I also get veggie from a few places but I prefer to use it in my car but also plan to use it in a generator very soon as well. I have tested it with the following fuels
Lard Fat, waste engine oil, waste veg oil, diesel, kerosene, hydraulic oil, gear oil and axle grease I have even used the fat from the turkey at Xmas.
The burner has a small pre heating tank with level and temp control , it comes with a 600w heater element but I changed mine to 150w heat rod as it is running from wind power most of the time. The burner also requires a supply of compressed air; this might cause a problem for some folks! I run a 150 lt compressor for the workshop anyway so it doesn't matter
The biggest challenge was with Lard fat and to some extent veggie oil, lard goes rock hard when cold and veggie goes gluppy, so they need to be stored in a heated insulated tank to keep them liquid. I only store about 15 gallons of heated fuel at a time; it only needs to be warm and liquid not hot. All used oils need filtering before use I have made up a processing tank to heat and filter the fuel from an old fridge on its back so that the door becomes the lid if you get my drift. I then fitted a small 18 inch household radiator panel inside and plumbed it into the heating circuit. With the addition of two 22mm tank fittings and two gate valves, one at the bottom as a drain and one about 6 inches up as an outlet for filtering.
That's the short version on how to do it, there are a few minor details not covered but it is all just common sense really. So far this setup has already saved me well over £700 in fuel and will have paid for itself by the end of April! Cant be bad!
Our oil supplier called last week to see why we had not ordered oil!
Regards Russell
Re: Question for Hilltopgrange (3.00 / 0) (#2)
by Gordy on Sat Mar 24, 2007 at 11:04:13 PM MST
Lonnie,
Here are a couple links to check out If you haven't already.
http://groups.yahoo.com/group/altfuelbabington/
and  http://groups.yahoo.com/group/altfuelfurnace/
Be warned there are as many ways to build or modify a furnace, as there are a wind turbine ;-) On the second site there has been some talk of manufacturers getting on the WVO band wagon, claiming there's will burn WVO. But their preheater is NOT adjustable, and won't get hot enough to give a good combustion with WVO.
Gordy
Re: Question for Hilltopgrange (3.00 / 0) (#3)
by huntedheads on Wed Jan 16, 2008 at 05:34:37 PM MST
I don't have experience with waste fryer oil but have burnt waste car oil for years and it is great (just try to avoid the deisel oil) and get all the transmission oil you can (hot) I dont have pics but can tell you all I know
  137 Scoop users have viewed this posting.
· Also by WindHarvester
