About ten days or so ago I lost the first wind turbine I built. It seemed to cook the stator then blades overspeduntil either hitting the tower or the tail. So far I've found 17 magnets.
And this morning I lost my other one, The "Firepower" one. I've been experimenting with it for a week or so trying to get it out of stall. I found a few issues with it, I dont know if I had the off set right for the tail, and also the pipe over pipe pivot for the tail had spread so when the tail was in the relaxed stage it went over center so was not keeping the blades straight into the wind until the wind was strong enough to move the tail slightly towards furl, then the blades would pick up some speed until the tail settled down again then it would slow.
So I added about1.6 ohms of resistance that would get up some speed to give 5-6 amps in most winds, but when the blades did hook up it would turn the nichrome wire the brightest orange and the blades would be scary! All I needed to do was connect a piece of # 10 wire parrallel with the Nichrome wire and that would put it back into stall and slow it down. And no matter how strong thw wind was, it wouldnt come out of stall with that wire connected. Until today... It was over 30 amps in 70 km winds, I connect the bypass wire and it got real warm and things dident slow down. I looked up to see a big chunk of stator hanging! And the blades, all 14 foot diameter were picking up speed!What a test on my tower! The turbine is mounted on a piece of 2 3/8 oil field pipe that sticks up out of the top of the tower about 5 feet,so as the wind gusted the pipe bends back lifting the blades away from the tower. This went on for 3 solid hours with wind getting worse. Finally the blades literally pulled apart from the root, leaving about 6 inches of root on each blade. I found one, but havent found the other two!
During some testing during the week, when I was getting 15 plus amps I also noticed the volts before going into the battery were often over 70 and as high as 77. That was measured before the nichrome resistance wire. Is this normal ? Isnt that fairly high? I realize the battery pulls that voltage down , just seems excessive. Maybe Delta is the way to go. So tonite I started laminating a set of 6 foot blades. Any ideas to make an ideal 48 volt wind turbine? Were 3 weeks off the grid and down by two wind turbines already. Both these machines appeared to be furling, but continued to increase in power. |
279 Scoop users have viewed this posting.
