I finally got my 3 hp 3 phase motor conversion up and running and everything seems to be working ok. Not sure if it will furl when it should.I will have to wait for some stronger winds to see if that part of it works as planned. I was surprised how fast it actually turns without a load. In a 15mph wind it quickly went to about 700 rpm.Very little blade noise and no vibration. I didn't leave it run that fast for too long. With a load it runs around 400 rpm in a 15mph wind. I'm using it to heat water for household use.The one thing I was surprised to see was that the windmill turns to a different direction when the brake is released and the blade starts to rotate. I drew a little skech insted of trying to explain it. Is this normal to rotate 90 degrees when the blade starts to turn? When the brake is on, the windmill follows the direction of the wind as shown in the skech below. Here are the dimentions of the mill.
- inch offset
- foot diameter blade (tsr 7)
- square feet of tail (1/8 inch thick aluminum)
- feet from hinge to end of tail
Would any of the experts have any comments? It has been an interesting winter project and will post some pictures when I get everything done. Thanks again to everyone for all the posts and pictures. It made it a whole lot easier building my first windmill!
181 Scoop users have viewed this posting.
