Diode or not diode?
By la7qz, Section Solar Posted on Thu Apr 19th, 2007 at 04:16:01 AM MST
How much real life loss from a diode in series with a PV panel?
| Hi
First of all, a little background information:
I am using three 55W PV panels to feed four Trojan T-105's connected as a 12V bank. I live aboard my boat full time and rarely have too much power, so I do not use a regulator. If my battery voltage is high one evening, that makes it an excellent opportunity to watch a movie. As there are so many times when part of the rigging may shade one or the other of the panels, they are wired in parallel to avoid reduced output from one panel affecting the whole array. The two panels that are permanently installed are mounted on the guard rail and if I leave the boat for several days, I'll simply flip them down so they are hanging vertical. That way, only one panel can get full sun at any time, and only in the late evening or early morning IF the boat happens to swing so that one side is facing the sun, so I reckon all I'm getting then is a maintenance charge.
In boating magazines and books, there is sometimes mention of PV panels and the writers usually state that there should be a diode in series with the panel to avoid the panel draining the battery at night. However, I have yet to own (or see) a PV panel of a size suitable for a boat that does not come with built-in diodes installed at both the positive and negative junction box. My three panels all have built-in diodes, so it is clear that another diode in series will do nothing other than cause voltage drop.
My question is how much real life performance drop am I going to see from an extra diode in series? The reason I ask is that on my last boat, I used a charge splitter (two hefty diodes in a box with big heat sinks) to feed both the house batteries and the engine starter battery from two 50W panels. I would like to do the same again to make sure the starter battery is always topped up, but preferably without losing too much power through the diode. The unit in this photo is similar to what I was using on the old boat. Overkill for the PV array of course, but I happened to have it available:
I also have another reason for wanting the charge-splitting diodes. On the old boat, I wired a relay in parallel with the panels between the panels and the diodes and used it to control my anchor light. A very simple and elegant solution which I would have liked to have this evening when I spent 45 minutes rowing about in the dark before I could find my boat...
On the same topic, is there any good reason I can't bypass the diodes in the negative junction box on each panel? I would think one diode in each panel would be sufficient? I can't really understand why the panels have diodes on both poles? Or maybe I could bypass all the built-in diodes and just use external diodes to feed the two battery banks? If there is no reason not to do this, it would solve all my problems including controlling the anchor light and there would be less voltage drop than I have at present with the built-in diodes on both poles.
Regards,
Owen Morgan
Yacht Magic
Falmouth Harbour, Antigua |
124 Scoop users have viewed this posting.
