Monday Rich knocked out a 24V stator for a 10' wind turbine. We cast it towards the end of the day... it came out nicely. I love the new plastic molds we made.
This is the water wheel we built with Scotty for his place about three years ago. Amazing how quickly time goes by. The page about it is here: http://www.otherpower.com/scotthydro1.html
It's been working well making about 20 watts 24/7 for the last two and a half years or so. (it's had a couple breaks when the creek has dried up but mostly it's been running). Recently the bearing play got so bad that the runner started banging on the frame/knocked a few vanes out of it and it stopped.
This is how it looked when Scott brought it up on Monday. At one point he replaced the runner we'd built with a squirrel cage fan thinking maybe it'd make more power. It didn't - but it made about the same so he left it on there. It's interesting to think that the bearing in this machine is from an old dodge - Scott removed it years ago from the car and used it on some kind of wood working machine. Then he removed it from that and we built this machine with it. On this unit - the bearing ran wet - with no grease cap, and no seal for 2 and a half years. It's shot now... but this confirms my thinking that we don't need to worry a great deal about the wind turbines we build with wheel bearings. We've made lots of wind turbines with used wheel bearings - we've never used the seal (it adds a lot of friction in my opinion) and we've never had a failure yet. I know this is a controversial point of veiw and I know that some folks have figured out ways to use a seal that provide for less friction. I'm impressed that this bearing held up as long as it did.
There's the old runner we made - hell put this back on next Monday after he gets a new bearing in there.
Pictured above you can see how wide the airgap was set on this alternator. We adjusted that to get the best performance from the alternator. The airgap must be about 1.5" on this machine.
Scott disassembles his water wheel.
Those are the magnet rotors - from an old dodge I believe. The polyester casting around them seems to have held up well - the nickel plate on the magnets is like new. There is a bit of magnetite built up on the magnets - not as much as Id have thought though. when we put it in I worried that it would pack up with magnetite quickly - that's not been a problem though. All in all it's held up very well considering this machine has been wet/sitting in the creek all the time.
We had a good spring snow storm on Tuesday (got about 15" here) so I finally got a good chance to burn all the slash left over from my tower site that we cleared about a year ago.
I use this honda for welding and pumping water. Our cistern ran dry on Tuesday so I started it up. It ran for about 5 min and just seized up for no very good reason. RIP - I don't like high rpm honda generators very much anyhow, although it was handy for welding on tower sites sometimes. I still have my listeroid diesel although it needs a bit of work and I've not used it all winter (I also want to move it closer to my shop). This was a bad time for the honda to die though -we're leaving for Guemes Island in about 1 week and I was counting on this for my wife to pump water/charge batteries if needed. She has trouble starting the diesel (crank start) - this was convenient with electric start.
Yesterday I hooked this up experimentally to see if I could run our well pump with it. Our well pump has a 3/4hp 220V motor - our inverter is a 120VAC Trace SW4048. I was pleasantly surprised to find that using this variac as an autotransformer worked out just fine. Its a big old 30 amp variac - probably made for dimming theater lights. It weighs a ton and seems to do the job well. It even runs my welder pretty well so long as I don't turn it up too high.
About 4 years ago in the old shop... this is the addition I built onto the 10x50 mobile home for a lathe.
Now it's a chicken coop... |
248 Scoop users have viewed this posting.
