| We have built a 1kW Hugo Pigott's machine and wished it to furl early (something like from 700 - 800 kW). In fact we will install the machine in a windy, isolated community and wanted to make sure the stator wouldn't overheat.
So we changed the design of our tail vane, wish is now a trapeze with a surface of about 9300 cm2. All angulars are 2" * 2" * ¼" and the plywood is ½" as in Hugh Pigott's manual. We added an aluminum angular (1.5" * 1.5" * 1/8"), 94cm length to help maintain the plywood.
To protect the plywood, we covered it with resin and fiberglass. The resulting weight is about 7kg. The metal part weight is about 21kg. The weight of the whole tail assembled is about 30.5 kg.The furling moment measured for the whole tail is 20 kg*m.
We put the tail at an angle of 110º to the turbine in the non furled position. The angle of the tail, dimensions of the body are like in Hugh Pigott's 12' manual.
Now our turbine doesn't take the right orientation, it's far from being front to the wind. It looks like the tail isn't sufficient anymore to compensate the action of the wind on the blades. Curiously when we stop the turbine short-circuiting it, the tail aligns with the wind as it should.
Could someone help us dimension correctly our tail vane? If someone has already made calculations for tail vanes or tested similar ones, it would be great to have some help to redimension our one... Or maybe someone has an idea of another possible reason why our tailvane doesn't work as supposed...
149 Scoop users have viewed this posting.
