Hi all,
This forum has lots of turbine pics but few details of the full rectifier installed. Thought I would show my third version which is much cleaner/safer than the crude setups that many of us had. No exposed wires. I have bonded ground to neutral in this box but have designed box so that bond can be in house at Inverter/lighting disconnect. Only one bonding point allowed per code.
This box is inside my battery shed out in yard. See my diary. The #6 red wires take battery to house 200' feet away thru the 30 amp fuse. Another 30 amp fuse is in between rectifiers and battery. Otherpower rectifier design with my additions and box. Even used their heat sink and bridge rectifiers. Tks Dan.
Last fuse is smaller, 3 amp for power to my meter in cover and shut-down relay. I am using a 120 vac heavy 3 pole relay in box for remote shutdown. Works fine at 48 vdc. Switch is in house and relay closes if battery gets disconnected for safety.
This pic is of basic components with many wires removed. Heatsink goes thru a rectangler hole in back. If others would use this basic format and tweek it with comments we may have a great design in a few more iterations. I can already see a few changes to make next time.(bigger box)
Finally the cover has a RC Electronics Watts Up meter in it. Works great and inexpensive. Much better than the old style volt and amp gauges I had in firt two versions. I would buy the Doc Wattson version next time for larger AmpHr readings.
http://www.rc-electronics-usa.com/buy-products.html
I have a switch on side of box to power it which also resets the AmpHr and WattHr log.
Hope this helps.
Rochester NY |
164 Scoop users have viewed this posting.
