Designed for 1.5" pipe stub to 2" pipe mast vai. reducer. 1 mast position 1 gin pole position.
The base is made of specialy coated 1/4" steel. Holes drilled in the base for 1/2" J bolts.
There is a compresion fitting for the 1.5" pipe stub.
I've used this tower base and I realy like it.
This unit normaly comes with a compresion coupling and J bolts. Those parts are missing. However this kit sugjested retail is $257.33.
I'm asking $100 plus shipping. It also comes with the tiltup tower manual. This is one awsome book with much easy to understand tower engeniering info.
It weighs 15LBs and comes in its original factory box.
Here a couple pictures.
Comments closed because it is sold.
