| Hi Guys,
My wing generator was hit by a bolt lightning a week ago and my wind generator and the devices attached to the batteries has been knocked out for six. The wind gen is installed with a lightning rod and the base of the tower is grounded. How the surge could go through the batteries and shot out the devices is beyond me and I am here for seriouly needed advice.
You can see my wind gen system here :
http://www.fieldlines.com/story/2006/2/26/21156/5171
The lightning rod is seen in Picture 2 and it is made from iron alloy coated by copper coloured coating.
Picture 8 shows the base of the tower and the 1 inch strip of thick real copper tape 3mm thick can be seen bolted to the base. This has been connected to an iron rod driven 6 feet into the soil. all the guy wires too are connected to iron rods driven into the ground. I was wrongly quite confident that any direct strikes will be dissipated by this system since the tower is all metal and it should conduct well.
From the stator of the generator runs 3 wires to my control shed where the AC is rectified to DC. The positive output from the rectifier pass a 60 amp fuse before the power reaches the batteries to charge them. I have three batteries in two different locations in the farm and each battery has a schottkys diode to allow charge to come in but not reverse. To the batteries I connect my gadgets. 1 battery runs a Car audio disc player where the power amplifier is completely toasted. This has been replaced. This battery is protected from overcharge by a shunt regulator which has been shorted and I hope to repair it. I have just completed another shunt regulator with a much simplier design and I am replacing it. This was thankfully sent to me by Glen Hurd more than 2 weeks ago. This is a real life saver.
Next to the audio set sits my electric fence energiser and this is powered by another battery used to start my engine driving a water pump. This has beed shorted and possibly salvagable. Waiting for the parts to arrive. A 2N2222A and a 2N3055.
In the other location the batteries are used to power a 10 watt light. This is controlled by a light sensor which switches on the light when darkness falls and turn it off at daylight. This relay is not working and I have not opened it to see if it can be repaired. I paid one of the local green energy company a ridiculous price of 125 ringgit USD 35/= for this simple sensor and relay control. They sell solar panels.
Somehow enough power came through the the wires to toast the schotkys rectifier, blow the 60 amp fuse and hit the batteries and all devices connected to them.
I am hoping to maybe add a surge trip control somewhere to trip the connections to add protection. Not sure where. I am also thinking whether installing additional fuses at the user end may further protect against damage. Example, the audio player uses only 3 to 4 amp max and if I put a 5 amp fuse on the positive wire to the player this will blow and protect the amplifier. The shunt regulator uses only a fraction of an amp and a 0.5 amp fuse at the positive power line may help. I was told by the local chap I need to put fuse to both the positive and negative line from the battery to have any protection if at all it helps.
Looking back the audio power amplifier was wrongly sitting on metal inside a fully iron locked cabinet cemented into the concrete to prevent theft. I shall install the new amp on an insulator board to isolate this. The radio-repair guy said the whole circuit has been toasted because the lightning came thorugh the metal casing of the amp even after the fuse of the amp has blowned. One puzzle, my electric fence energiser is not connected to the wind generater and it still was hit. I think my farm was hit more than once and one of them must have hit the electric fence. The negative pole of the energiser is connected to the ground wire of the electric fence and the wire from that source to the energiser shows burnt mark. I should have grounded this negative rail separatly.
So Guys, what do I do now before I go on line with the wind generator and before the next lightning strike? Please help.
SeanChan from Malaysia.
194 Scoop users have viewed this posting.
