Corry VWAT
By wdyasq, Section Wind
Posted on Sun Sep 23rd, 2007 at 06:03:33 PM MST
Out of patent now - Build your own
Will Corry was or is a personal friend of mine. I haven't heard from him in years.
He built and patented this wind device 22 years ago. I thought I would post this for the VAWT fans.
http://www.otherpower.com/images/scimages/284/corry.pdf
Corry VWAT | 18 comments (18 topical, 0 editorial)
Re: Corry VWAT (3.00 / 0) (#1)
by fungus (info@reenergy.co.uk) on Sun Sep 23rd, 2007 at 12:39:49 PM MST
21 blank pages?....
Fungus - www.reenergy.co.uk
Re: Corry VWAT (3.00 / 0) (#5)
by feral air on Sun Sep 23rd, 2007 at 01:04:04 PM MST
Not blank on my end.
I'll save you the trouble...it's complex and if there's anything new about it it's probably not worth the effort. You'd be better off making a few simple S vawts instead of spending the same time and money building one of these.
I just skimmed it though, so I could easily be wrong. It looks like maybe the blades change angles and/or shape? I dunno..KISS.
Re: Corry VWAT (3.00 / 0) (#16)
by jimjjnn (jimjjnn at yahoo dot com) on Mon Sep 24th, 2007 at 09:45:03 AM MST
It's way too complicated !!
Too many things that can go wrong. Not KISS, for sure. Looks expensive to build, also.
Jim Denver,CO
Re: Corry VWAT (3.00 / 0) (#2)
by wdyasq on Sun Sep 23rd, 2007 at 12:53:49 PM MST
well - patent number 4545729 - worked for me from my files.
The editor may remove if teh link doesn't work - sorry folks.
Re: Corry VWAT (3.00 / 0) (#3)
by gotwind2 (ben[at]gotwind.org) on Sun Sep 23rd, 2007 at 12:57:21 PM MST
(User Info) http://www.gotwind.org/index.htm
It does load up o.k - It is a pretty large file, that's all.
Ben.
www.gotwind.org
Re: Corry VWAT (3.00 / 0) (#4)
by dinges on Sun Sep 23rd, 2007 at 01:03:49 PM MST
40:004:018 And Jesus, walking by the sea of Galilee, saw two brethren,
           Simon called Peter, and Andrew his brother, casting a net into
           the sea: for they were fishers.
40:004:019 And he saith unto them, Follow me, and I will make you fishers
           of men.
Wdyasq - a fisher of men ?
Who'd have thought...
Re: Corry VWAT (3.00 / 0) (#7)
by TomW on Sun Sep 23rd, 2007 at 02:33:44 PM MST
Peter;
Yeah, but not just using a hook and line or a cast net but a whole fleet of trawlers...
Still; 99.999% vapor as far as hardware goes near as I can tell.
Re: Corry VWAT (3.00 / 0) (#6)
by strider3700 on Sun Sep 23rd, 2007 at 01:13:42 PM MST
I've got a few questions if you happen to know the answers to them.
Did anyone ever actually build one of these?
Did it actually function with any advantage over the simpler designs out there?
It looks cool but wow is that ever complex looking with all the moving pieces. I'd expect maintenance to be a huge part of life with units like this.
Re: Corry VWAT (3.00 / 0) (#8)
by wdyasq on Sun Sep 23rd, 2007 at 04:54:58 PM MST
"He built and patented this wind device 22 years ago."
It self regulates and can be built of simple materials.  Once one gets past the complexity of the drawings it is pretty simple.  It may have an advantage in low wind areas.
Re: Corry VWAT (3.00 / 0) (#9)
by vawtman (vawtman(at)charter(dot)net) on Sun Sep 23rd, 2007 at 05:21:29 PM MST
GO PACKERS
Re: Corry VWAT (3.00 / 0) (#10)
by dinges on Sun Sep 23rd, 2007 at 05:42:04 PM MST
This particular patent was not awarded to your friend Will Corry but to Joe Storm.
The Corry patent has nr. 4.457.669 (1984 patent for a "Jibe windmill") and can be found here:
http://tinyurl.com/ysvn92
Scanned images of the patent can be found by clicking the link below (you may have to install a special reader to view the images; I use AlternaTiff: http://www.alternatiff.com/ )
http://tinyurl.com/2xcjm7
Had to turn the links into TinyURLs as Scoop kept messing up my original direct links to the US Patent Office.
Re: Corry VWAT (3.00 / 0) (#14)
by boB on Sun Sep 23rd, 2007 at 09:42:32 PM MST
(User Info) http://bob.gudgel.org
Another handy (and free) way to download patents as .PDF is to go to
www.pat2pdf.org and enter the patent number.
boB
Re: Corry VWAT (3.00 / 0) (#11)
by CmeBREW (smke833f@hotmail.com) on Sun Sep 23rd, 2007 at 06:16:56 PM MST
Thanks Ron.
-Looks too difficult and problematic to me. I like only ONE moving part myself!! I'm stickin with the simple good ol' "Squirrel cage" Vawt! Air flows thru it real good. I made a proto-type rotor today and it looks VERY promising. It goes fast. Looked like over 200rpm in almost nothing of a breeze. It was one of those 0-4mph occasional breeze evenings. I just got it up a few hours ago. It is only 18" diam. by 39" high. I'm making the bigger one hopefully this week. I believe it will self-regulate in high winds. Can't wait to see that!
Does anyone know where I can find a 10 foot piece of 6" diam. PVC THIN WALL drain(or sewer) pipe??  I can only find 4" which is what I make the proto out of.
Re: Corry VWAT (3.00 / 0) (#12)
by BrianK on Sun Sep 23rd, 2007 at 07:00:27 PM MST
I dont know where you live but if your near Ohio I am lucky enough to live just down the road from a plastic pipe company. They sell to us locals. not to sure what all sizes they sell but I do remember when I used to work there I made what they call 6" sand pipe. I can ask them all the sizes. now shipping would be the big issue.
Re: Corry VWAT (3.00 / 0) (#13)
by CmeBREW (smke833f@hotmail.com) on Sun Sep 23rd, 2007 at 07:14:21 PM MST
BrianK, ---Where In Ohio. I am in Ohio. Is it near Columbus or Cleveland? I've never heard of 'Sand pipe'. I believe that 'ditch pipe' is thick and expensive. I was looking for something 6" diam. -but not TOO expensive. That 4" PVC(thin wall) drain pipe I got was only $7 a 10' section at Lowes. Do you have the name of the Company?
Re: Corry VWAT (3.00 / 0) (#15)
by thefinis (thefinis@hotmail.com) on Mon Sep 24th, 2007 at 05:24:40 AM MST
Due to the reduction in stiffness as the diameter gets larger you might be better off to just get regular 6 or 8 inch pvc which should not be hard to find. The drain pipe is available in those sizes too but if it is hard to locate or much farther off to pickup then the savings on pipe cost may get lost in time and gas cost.
Watch around new apartment construction or water or sewer construction as they often discard anything leftover that is not a full length piece.
Finis
Texas born and bred
Re: Corry VWAT (3.00 / 0) (#17)
by BrianK on Tue Sep 25th, 2007 at 12:16:35 PM MST
CmeBREW, not near Cleveland or Columbus. Over west of Lima about 12 miles from the Indiana line
Re: Corry VWAT (3.00 / 0) (#18)
by CmeBREW (smke833f@hotmail.com) on Tue Sep 25th, 2007 at 02:09:07 PM MST
Yeah, thats a long way away. Thanks anyway. I was just hoping someone might know a common store that sold it, that I overlooked.
I am believing that the WEIGHT of the rotor (&PVC)is a major issue. I'm just going to keep using that thin lightweight (1/8" thick) 4" diam. "Drain pipe" PVC for now. That design that Ron just showed us sure looks heavy to me! Also, BALANCE is very important as I'm learning.(especially for a strong wind) Thats why Im afraid of depending on moving parts on or in a rotor, myself.  However, someone might get an idea from part of that design. Thanks for showing it.
  189 Scoop users have viewed this posting.
· http://www.otherpower.com/imag es/scimages/284/corry.pdf
· Also by wdyasq
