I'm planning on hooking up both a set of 3 HF 15 watt panels, and a 200 watt genny this weekend.
I've got a xantrex c-35 that I'm going to be using in diversion controller mode.
I'd suppose that using a single source might negate the need to use blocking diodes to keep the battery from feeding the panels or genny but when using more than one source, should I use blocking diodes to keep the genny from trying to feed the panels and the panels from trying to feed the genny? |
172 Scoop users have viewed this posting.
