never before have i played about with magnets.
so now i have a rotor 4 1/8" dia and would like to shave off about five mm.
on the rotor are ceramic magnets four .90deg each.
is it possible i can turn the rotor in a lathe and just treat it like a bit metal.
as yet i am only thinking. i do understand there verry brittle. like a floor tile.
as far as i know floor tiles are cut wet with a diamond disc.
the ceramic is about 8mm thick . i want to leave about 3mm or 4mm.
then put neo on top .the same pole setup. will bond them on.
i could grind them with a stone cutting disc.
but that makes a lot of dust.
dos ceramic obsorb water.
theres a few chips broken off allready.
so are thay toxic or am i just thinking negitive.
so how best to reduse the dia on rotor.
be nice to hear from others who cut magnets |
79 Scoop users have viewed this posting.
