| I'm having a problem with my solar system. Right now I have 195 watts of solar hooked up to 4 new 125 ah batteries controled by a sunup charge controler. The output of the controler I have connected to a bus bar system.
Now the problems.
- The controler shuts off power to the buss bar every time I try to connect any other device to the bus when the inverter is connected (700 watt Victor) even when the inverter is off and there is no load on the other devices.
- Yesterday I was able to power the computer with the inverter but today when I power up the inverter I get nothing while the computer is pluged in. If I unplug the computer shut down the inverter and restart I can plug in a small radio and it will run if I plug in the computer the inverter shuts down. I don't get it there is not much draw with the tower shut down. I just had a stray thought I had been using the computer on grid before I changed to the solar setup could the electronics being warm from use case this?
- The controler is showing a different charge level than I get with a volt meter when the system is actually working. IE yesterday when the computer was on the system the volt meters showed a bank reading of 12.6 but the controler showed 13.8 and was shutting of the imput from the solar bank. When the draw on the system is smaller the readings are very close.
Any Imput as the the case of my problems would be helpfull.
Jan |
95 Scoop users have viewed this posting.
