3 phase rectifier price range
By Boss, Section Controls
Posted on Sat Jan 12, 2008 at 06:03:07 PM MST
Is it my imagination or are they a little too proud of it?
This 3 phase rectifier on ebay has a starting bid of $49.95
<phase rectifier>
3 phase rectifier price range | 9 comments (9 topical)
Re: 3 phase rectifier price range (3.00 / 0) (#1)
by DanG on Sat Jan 12, 2008 at 11:34:12 AM MST
That link fought against viewing on my machine...
http://search.ebay.com/350014401049
For a new component with 800 Volt 150 amp rating that about average on ebay...
Pulls from end-of-life industrial processes or assembly line controllers, etc. are much more affordable unless there is a bidding war - but new means no mystery about it ever being abused before and commands about 2x the price, at least on high current devices...
Re: 3 phase rectifier price range (3.00 / 0) (#2)
by Boss on Sat Jan 12, 2008 at 11:42:01 AM MST
Thanks for the info
Yeah I had some difficulties posting the link. Not sure of the syntax for a link
That is the item # 350014401049
This was my first look so I'll keep looking, there is no rush
Brian Rodgers
Re: 3 phase rectifier price range (3.00 / 0) (#3)
by bob golding on Sat Jan 12, 2008 at 12:44:25 PM MST
hi Brian,
have a Lock at cti surplus. they have them fairly regularly and at lower prices.
cheers
bob golding
Re: 3 phase rectifier price range (3.00 / 0) (#4)
by sPuDd on Sun Jan 13, 2008 at 05:50:05 AM MST
You guys have it too easy over there.
That puppy would start at $100 surplus here in Oz.
It'd be $200-$300 new from supplier, AND we would
pay even more to get it shipped over!
sPuDd..
Re: 3 phase rectifier price range (3.00 / 0) (#5)
by Boss on Sun Jan 13, 2008 at 06:31:51 AM MST
That is outrageous
for three HV diodes in one package? Better off just building our own. Now, I think I asked this already and pardon me for sitting here and not just going out to the shop and looking, but don't microwave ovens have big HV diodes on the magnetron circuit?
Brian Rodgers
Re: 3 phase rectifier price range (3.00 / 0) (#6)
by fungus on Sun Jan 13, 2008 at 06:34:46 AM MST
They are high voltage but only around 1A current capacity as far as I remember.
Another way to make a nice rectifier is to use stud diodes, google search the board for more information.
Fungus - www.reenergy.co.uk
Re: 3 phase rectifier price range (3.00 / 0) (#7)
by Boss on Sun Jan 13, 2008 at 07:08:24 AM MST
You are right, I first went to a supplier I used before MCM electronics but they don't list many diodes like I have in stock. A more general Google search found this. Note these are all higher voltage than we want with lower amperage rating (less than an ampere.)
http://www.amiparts.com/partslist/hvdiode.htm
 Microwave oven diodes
AA-1140      Female Terminals, Wire Gauge: 22-18, Tab Size: .250      Go to Section
AMCT-1     Non Insulated Terminals, Male Terminal, Wire Gauge: 22-18, Tab Size: .250, Qty Per Pack: 50     Go to Section
AMI2066     High Voltage Diode - 1/4" FM quick connect on cathode lead, 3/16" FM quick connect on ground lead. Overall length 3 1/4". 12KV 350MA, Replaces: Popular in Tappan Home Microwave Ovens. Direct Replacement for Tappan Part # 5303091303 and more     Go to Section
AMI3347     HV Diode - Will replace any commercial or home microwave oven diode with 2 leads. 16KV, 750MA     Go to Section
AMI3D71     HV Diode - 12KV 350MA, will replace any home unit with 2 leads.     Go to Section
AMI9509     High Voltage Diode - 3/16" quick connect on cathode lead, round grommet on ground lead. Overall length 3 1/4". 12KV 350MA,     Go to Section
AMI9510     High Voltage Diode - 1/4" male spade on cathode lead, round grommet on ground lead. Overall lenght 3 1/4". 12KV 350MA, Replaces: Popular in Amana, Whirlpool and other home ovens.Replaces Amana R0156595     Go to Section
AMI9511     High Voltage Diode - 1/4" FM quick connect on cathode lead, ring terminal on ground. Overall length 8 1/2".12KV 3 50 MA, Replaces: Popular in many Sharp microwave ovens     Go to Section
AMI9512     High Voltage Diode - 1/4" FM quick connect on both ends. Overall length 3 1/8". 12KV 350MA, Replaces: Popular in Amana, Magic Chef & and other home ovens.     Go to Section
AMI9513     High Voltage Diode - 1/4" FM quick connect on cathode with 8" lead wire, with 1/4" FM quick connect. Round grommet on ground lead. 12KV 350MA. Replaces: Popular in Sharp, Replaces Sharp # FH-DZA009WRKO, FH-DZA015WRKO, Tappan Part # 5303212799, FW-QZA040WRKO, Amana Part # R0809505 and more.     Go to Section
AMI9514     High Voltage Diode - 1/4" FM quick connect 8" lead wire, with 1/4" FM quick connect on cathode. Extra 6" long wire with ring terminal on ground lead. 12KV 350MA. Replaces:     Go to Section
AMIBA10B     High Voltage Diode - O.E.M.#BA10B Diode, P.C. Mount, Replaces:     Go to Section
BB-1141     Female Terminals, Wire Gauge: 16-14, Tab Size: .250     Go to Section
MCT-1     Non Insulated Terminals, Male Terminal, Wire Gauge: 16-14, Tab Size: .250, Qty Per Pack: 50     Go to Section
MMFA     Brass Tab Adapters Tab Size: .250     Go to Section
THV512     HV Diode, 1/4"FM quick connect on cathode lead, round grommet on ground lead. Overall length 3 1/2" 12KV, 350MA     Go to Section
2B72757B     H.V. Transformer - Fits over 40 models of Frigidaire, Sears, Tappan and Whirlpool microwaves.     Go to Section
N685     High Voltage Transformer - PRI. 110V., Fil. 3.0V., OHMS 135, H.V. Secondary 2,130V. (For use in 600 watt or less microwave ovens) 3 1/8" w. x 4 1/2" d. x 3 7/8" h., Mfg. by Magnetek-Triad (#N685-7070)
Brian Rodgers
Re: 3 phase rectifier price range (3.00 / 0) (#8)
by TomW on Sun Jan 13, 2008 at 09:21:17 AM MST
Brian;
Don't forget Automotive / Truck Alternators all have a 3 phase rectifier in them.
Might raid the local auto wrecker and snag a good few. Give them good heat sinking as they are used to lots of air over them.
More than one way to rectify a sine wave.
Re: 3 phase rectifier price range (3.00 / 0) (#9)
by Boss on Mon Jan 14, 2008 at 05:15:20 PM MST
Thanks Tom
I have a decent junk yard here, I'll start scavenging
Brian Rodgers
  125 Scoop users have viewed this posting.
related_links: This box seems to be broken. Please email the site admin and tell them the time and date (and your timezone) so it can be fixed.
