Hi Guys,
I have built a number of VAWT prototypes. I am achieving lots of torque with about 45rpm at 12kph winds with 10sq meter sail areas. My Vawt is similar to US PATENT 5525037 dated june 1996. http://patft.uspto.gov/netacgi/nph-Parser?Sect1=PTO1&Sect2=HITOFF&d=PALL&p=1&u=%2Fne
tahtml%2FPTO%2Fsrchnum.htm&r=1&f=G&l=50&s1=5525037.PN.&OS=PN/5525037&RS=PN/5
525037
The big issue is power generation. Due to the nature of wind fluctuating - and the requirements of generators to have fixed hi revs with plus or minus 10 percent tolerance I am looking at alternate methods.
One idea is steam. If a turbine could heat water to generate steam, it would provide a simpler system to link multiple VAWTs. The steam could also be directly employed to heat my home - provide hot water - drive compressors to provide air conditioning and refrigeration - as well as drive a steam turbine to provide main power and dump surplus to the grid.
I am experimenting with rotating cavitation drum water heaters to heat the water.
Has anybody else gone this route with VAWTs?
Sample of water cavitation heater can be found at http://www.youtube.com/watch?v=yh_-DUKQ4Uw&NR=1 |
