Woke up this morning to this.
It was a recptical for the buts of my resident smoker, which caught fire fanned by winds and caused a bit of damage. The two conduits are power from the inverters and a cable returning to the battery shed for small power.
Dug down and exposed the incommer, problem is they were burnt at ground level.
Two new cables patched in until full restitution can be made.
The other cables in the pics are com's cables bringing data from the battery shed.
I will be able to place a junction box a little out from the wall and be suficiantly above ground. Amazingly the power stayed on, the feed from the inverter(25m) is a 4mm sq cable protected by a 20A MCB the other is a 2.5mm sq feed to the battery shed from the fuse board which has earth leakage protection and a 15a MCB. MCB = minature circuit breaker
allan down under |
122 Scoop users have viewed this posting.
