a cheap solution for RPM?
By zeusmorg, Section Wind
Posted on Sat Oct 18, 2008 at 01:44:40 PM MST
I found this for RPM?
 Ok I found a possible solution to cheap rpm reading.
http://www.dealextreme.com/details.dx/sku.2682
  I haven't tested it, nor do I endorse  it. But hey for 5 bucks it has rpm readings, so no conversion from a MPH reading needed?
 I could see this as a cheap solution for windmills, or even building a home brewed anemometer. Ordered one to play with..
a cheap solution for RPM? | 2 comments (2 topical)
Re: a cheap solution for RPM? (3.00 / 0) (#1)
by Norm on Sat Oct 18, 2008 at 09:30:36 AM MST
Yes....they really work I have 2 similar that
cost twice as much....but work quite well.
May get some more at that price !
I'm sure you'll have fun with it.....
thanks for the info !
( :>) Norm
Re: a cheap solution for RPM? (3.00 / 0) (#2)
by kc5etv on Sat Oct 18, 2008 at 12:35:19 PM MST
Here is one that I found it is a PC program and just add a burglar alarm switch on the turbine and away you go.
http://www.hroch.net/sidparal/software/serialtacho/index.html
It has been work well on mine.
KC5ETV Les
  176 Scoop users have viewed this posting.
· http://www .dealextreme.com/details.dx/sku.2682
· Also by zeusmorg
