Rolling blackouts/battery backup
By dnix71, Section Homebrewed Electricity
Posted on Wed Oct 29, 2008 at 12:38:28 AM MST
and plug in alarm clocks
We had the first cool weather of the season last night in south Florida, and with it rolling blackouts all night long. People here don't have proper heat and resort to using the electric range or plug in resistance heaters. It's even cooler tonight, so I hope FPL has made arrangements to buy extra power.
My alarm clock was plugged into a small UPS, rather than the Aims inverter on my battery bank. I didn't like the idea of leaving the Aims on 24/7.
But I couldn't sleep with the power failing every hour or so and the UPS alarm going off. Eventually the UPS battery failed, so I plugged the clock into the inverter anyway. If I'm late to work, my employer might give my job to someone else, and the way things are, I'm lucky to have a job.
I cracked the case on the alarm clock and a spare I had recently bought from Walgreens hoping to find a way to run them from dc. Unfortunately both clocks use at least 2 voltages and the both use low voltage ac to run the the clock. Reading the fine print I discovered the newer clock won't even sound the wake up alarm if the power is out. Both clocks use a 9 volt battery to keep settings in a power failure, but there is no display in backup mode.
After hurricane Wilma, I didn't have electric for almost a month. If that happens again, I'l have to charge AA batteries from a car adapter charger hooked up to my battery bank and use them in a travel alarm clock I have.
When I was growing up my father used a wind up alarm clock. I'm not sure those even exist anymore.
Rolling blackouts/battery backup | 5 comments (5 topical)
Re: Rolling blackouts/battery backup (3.00 / 0) (#1)
by kurt on Tue Oct 28, 2008 at 07:27:14 PM MST
hmmm my mother used a battery powered analog alarm clock for years used 2aa batteries the batteries in that thing lasted at least a year and she used it every night. the face even glowed in the dark something like this http://www.hardwareandtools.com/invt/u635845?ref=gbase
i used to have a manual wind up clock like this it worked OK it didn't keep the best time but as long as you set the time once a week and wound it every day it worked great
http://www.hardwareandtools.com/invt/u178555
IRC inst.
Re: Rolling blackouts/battery backup (3.00 / 0) (#3)
by dnix71 on Tue Oct 28, 2008 at 07:54:23 PM MST
The battery alarm clock I have has a backlight but the light uses a "C" battery. The clock and alarm use the same "AA."
Re: Rolling blackouts/battery backup (3.00 / 0) (#4)
by jimjjnn on Tue Oct 28, 2008 at 08:23:06 PM MST
I use the radio clocks from Radio Shack and haven't replaced the batts in 5 years. They each use one AA battery. And keep time via the radio signals out of Ft Collins ,Colorado.
The alarm never fails to wake me. I bought them on sale for $10.99.
Always accurate to .001 second and are readjusted all the time by radio link.
I have 3 of them around the house . No problem with any of them.
Denver,CO
Re: Rolling blackouts/battery backup (3.00 / 0) (#2)
by ghurd on Tue Oct 28, 2008 at 07:29:25 PM MST
Even the 99% of the Amish use battery clocks now,
http://www.ahwco.com/index.html
But if you need a wind-up, I can find one.
Ghurd.info
Re: Rolling blackouts/battery backup (3.00 / 0) (#5)
by thefinis on Thu Oct 30, 2008 at 01:44:47 PM MST
Last time I checked Wally world still carried them. We used to keep one around to put in a new puppy's bed at night. The tick toc helped keep them company and slowed the whining and yelping down some.
Finis
Texas born and bred
  77 Scoop users have viewed this posting.
· Also by dnix71
