| Hello all,
As I have said in previous posts, my knowledge of circuitry/electronics is rather limited. I guess I may know some basic stuff, but basically what I know is enough to get myself into trouble concerning whether I really know what I think I know. I do however have a friend who is an Electronics guru, but his lack of interest/knowledge concerning wind generation; I need to explain a few things to him before he can help me design a controller. A bright side to this is that I do have some experience programming embedded devices(not a whole lot but some) So K.I.S.S. concerning using a programmable device, is not too much of an issue for me. Another problem I have is when people start talking technical I tend to get lost(lots to know concerning wind generation). So, with that said, let me lay out what I think I know, and then if someone would be kind enough to correct me where I am wrong, and fill in what I may have missed . . . any help would be greatly appreciated. SO here goes.
The idea of MPPTs is to maximize power output from a power source. The context I will be speaking of here concerns wind power. What I think I know is this:
A machine that is loaded 100% of the time depending on wind speed may not be working at its full potential. Since there is little power to be obtained in wind under 6-8mph, we may want to leave the machine unloaded until we obtain enough speed to keep our blade RPMs high enough to maintain a starting load. At this point, we figure what is an acceptable load to keep the RPMs up, letting through just enough power to maintain our present RPMs. Wind speed then increases slightly to allow us to increase the load, we then check what is an acceptable load while maintaining our RPM, and if so allow the load to be drawn. Our MPPT does this at set intervals until we approach an optimal/safe rotation speed.
Assuming the above is correct, how does this keep our TSR in range? How can a MPPT keep an alternator at high RPMs from losing efficiency thus keeping the stator from overheating ? On the latter here I am thinking that since a given machine could put out more power than it was designed to put out 'safely', at some point we decide on a 'current cut-off' and allow no more current to be drawn. Also I am thinking that this has potential for an over speed condition, where our concerns would be failing mechanical parts (blades, bearings, etc) rather than electrical. This is where I am assuming braking(if at all possible to be done safely/smartly), or more likely furling would come into play. I would also assume that rethinking a furling system because of a different load scheme would be necessary.
What have I missed ? |
Wind MPPTs | 25 comments (25 topical, 0 editorial)
83 Scoop users have viewed this posting.
