Had the opportunity to pick up 20 ( NdFeB ) magnets ,ordered 4 more very priceee,
1 x 2 x 3/4 grade 50 ,you know what I mean priceeee.
Had a stator all made up 70 turns aws 14 , and a set of rotor 12".
Got it all put together .
And hers the question , don't know how to set it up, that is the Gap.
This is how it tested
With the Gap set at 25mm ( stator is 14.5 mm thick ) this give it 5.25 mm
magnet face to stator .
Turning by hand and having it hook up to the rectifier and batteries ,12 volts at 109 rpm
and a little hard to turn. At 24 volts 187 rpm 24 volt turns very easy and you can see the amp
meter moving.
What or how to set it up the best?????? |
185 Scoop users have viewed this posting.
