| Hi
My wind turbine has now been up for a few weeks and I find myself for the first time in my 16 years of living afloat in the position of having more energy than I know what to do with. I know that I could easily resolve this issue by installing a 12V refrigerator, but I have thought of a more useful way to use the power. (There's cold beers and good company on land.)
I have decided to install a 12V heating element in the hot water tank and use a dump load regulator to dump power to the heating element. I simply don't have time to build anything from scratch at the moment, so I'm looking for recommendations on which regulator to buy.
I have previously installed a Xantrex C/40 on a customer's boat which seemed to work just fine, but I know some members of this forum have reservations about that particular brand. The wind turbine I'm running at the moment is capable of producing a maximum of around 25-30 A, but typical output is more like 5A most of the time, up to 10-15A in gusts. In addition to the wind turbine, I have 165W worth of PV panels.
I also have another turbine of around the same capacity which I have not installed yet, so I could potentially see output up to 60A in strong winds. I would normally shut down one of the turbines in higher winds. The Xantrex C60 seems a likely candidate, but other suggestions are welcome.
Any hints for sources of 12V immersion heaters would also be very welcome. The best plan might be have a regulator capable of dumping the power from both turbines and install two 12V immersion heaters and disconnect one when only one turbine is in use.
Owen
Yacht Magic
St. Maarten
Netherlands Antilles |
