March 2007, I posted the first pictures of an eight inch turbine that was under construction. Here is a picture of the unit last year.
The roughed out disks sat on my shelf till last week. I found an eight inch Flexatolic stainless steel ring that fit the description of what would finish the disk. Here are two pictures of the finished turbine disk.
A small lip was machine on the inside of the ring. Next the two plates were machined with the opposite lip. Then three bolts tie the whole assembly together. The 1/16" plate serves to cover the balance holes and a slinger for water.
The entire disk assembly was balanced and polished. It came out very true and will be operate around 10,000 rpm. The alternator will be directly connect and designed for 500 watts at that speed. Next the bearing and housing. I hope it will not take another year.
Joseph. |
146 Scoop users have viewed this posting.
