I've been doing a lot of reading on the construction of a Savonius turbine, and have found that most of the research out there says the Savonius rotor is very inefficient. I have been doing some experiments with this turbine because I believe that with a modified construction of the rotor the TSR(tip speed ratio) can be drastically increased. I will post in a later thread pictures of the rotors I have re-designed. Also, I am curious if anyone has heard of using two separate Savonius rotors moving in two different directions to increase the speed of the turbine. I think by doing this in combination with the axial flux generator, the efficiency of this type of turbine can be greatly increased. I really like the design of Verticle axis turbines and believe that overall they hold a key to providing more power than the conventional Horizontal axis turbines because of the torque created from the sail like rotor. If anyone has any feedback on this topic it would be greatly appreciated. Thanks!
141 Scoop users have viewed this posting.
