| Thought I'd make a start on documenting my 10 footer project so here goes.
Maximum of 1kw of wind power to drive one of two 1kw pumps on my swimming pool.
Since the power is mostly being used as soon as it is available, minimum storage is required. No big deal if the filter or solar pump doesn't run for a couple of days due to there being no wind.
No dump load required since the pool pumps ARE the dump load. They will always be available to take the excess power from the battery bank when it gets up to a pre-determined point. I'll probably put in a 'crowbar' arrangement so that if the battery bank get more than 2 volts above the normal load cutin point, the generator output is shorted - either that or if the inverter fails to start then a short is applied a couple of seconds later.
* 10 footer as per Hugh Piggott "How to build a wind turbine" with 24volt stator from Otherpower, set to furl at 1000w
* Tower - I have a choice of 4" thick wall steam pipe at about 11m high or a few sections of 140mm irrigation pipe to get to 15m high. The latter is my best choice but nothing has arrived on site yet from a mate!!
* charge controller to start an inverter at 28volts and cut out at 22volts (using the basic 555 design to start with but later using Dallas 1-wire DS2438 battery monitor chips)
* Overcharge protector - probably a relay and a zener diode to start with to short the output of the genny if the battery bank over volts
* Battery bank made from recovered 150amp/hr truck batteries - aiming for 8 in series parallel for 24volts at a nominal 600amp/hrs (but nearer 300amp/hrs since they are pretty rough)
* Pump controller which juggles the demand for heat from the solar panels and minimum dosing of the chemicals each night but ensuring that one pump will ALWAYS load the inverter when it becomes active but avoid connecting the inverter to the mains!
- More CAT5 cable round the property to allow statistics collection of the state of each battery in the battery bank using the DS2438 chips
- Collate generator output with the weather station to see how it varies through the year
- More intelligent controller using the 1-wire chips
- More intelligent control of the pool pumps so that minimum water temperature etc can be maintained by using mains power if required
Pictures of each block should be available for posting by the end of Feb (by which time I hope to be test flying the genny) |
145 Scoop users have viewed this posting.
