This last year I have been working on getting some back-up power in the house.
I live in Florida and almost every year we deal with power outages due to hurricanes.
Although a couple of days without power is nothing life-threatening, it certainly is uncomfortable if the temperatures are in the 90's. I started with building a small ametek turbine, but it is really not enough to give reasonable power. So I started on a dual rotor 6.8ft diameter turbine. This is still a work in progress.
Recently I purchased a 20Watt solar panel and installed it in the backyard.
With my limited knowledge of electronics I built a small control panel to manage the incoming power. Currently, it is charging two 12volt batteries. One is 110AH Trojan and the other is a small 20AH battery. It is charging one or the other.
A main switch can disconnect the solar panel. A cheap sunsaver is controlling the input and the output.
This seems to work out fine.
The main problem has been to know what to do with all the energy I'm accumulating (admittedly very little power, but it is expandable;). The batteries are in our shed while I will need the energy in our house. I do not want to lug those extremely heavy batteries back and forth.
The current solution is very not very efficient, but it gives me great flexibility.
I am charging AA batteries from the 12volt batteries. Two chargers, which I can turn on or off, are hooked up to the electronic board.
The charged AA batteries will be used for anything from powering a small lcd tv to led flashlights. I also have 3 24volt computer fans that I am running of rechargeable 9volt batteries. I bought some D cell battery converters that let me change 2 AA batteries into 1 D cell battery, so I only have to charge AA batteries.
So far, I'm happy with this solution. I know it is terribly inefficient, but I can't think of a better way to have backup power. I don't want to run wires all over the house to run 12volt appliances.
If anyone has a better idea, I'm certainly open for suggestions.
Or if anyone sees a mistake in the control panel, please let me know. I don't want to set the house on fire.
When my turbine is finished (hopefully in the next few weeks), it will be added to the system on a separate battery. But that is a topic for another diary. |
155 Scoop users have viewed this posting.
