| I re-did my first alternator to add a second steel disc as Flux suggested so now I have an 8" disk with 12 of windstuff Ed's wedge magnets, a stator 3/8" thick and then a second steel disc (no magnets) to complete the flux circuit.
Adding the second disc gave me a more steady output at, and a little above cut in but with very good wind today it is being held back to only about 200 to 250 RPM at most. Before adding the second disc it would be spinning out of control with this wind.
The obvious thing to do (I think) is open up the air gap a little. The gap now from magnets to second disc is about 5/8". Another 1/8" should give it a little room to stretch out. Now I'm wondering...
Question - Should I just move the second disc out leaving a small space between magnets and stator and a larger space between stator and the second disc, or should I keep the stator centered between the discs? Or, does it not really matter?
I'll do it tomorrow and would like to set it up right the first time. |
76 Scoop users have viewed this posting.
