bus
By windspeed, Section Mechanical
Posted on Sun Mar 23, 2008 at 11:41:25 PM MST
electrical connections
In my efforts to recycle
I wondered if flattened copper tube with brass bolts and nuts would work as an electrical bus connection
Terry
bus | 4 comments (4 topical)
Re: bus (3.00 / 0) (#1)
by WXYZCIENCE on Sun Mar 23, 2008 at 08:05:50 PM MST
Terry, copper tube (Eg. 1/2 inch) works well for bus connections. Drilling holes in it can be somewhat precarious. I use a hole punch to make my connection holes. I also use 1 inch lengths to make connector lugs.
Joseph
Re: bus (3.00 / 0) (#2)
by wooferhound on Sun Mar 23, 2008 at 11:35:41 PM MST
Using uninsulated wire/tube to make battery connections is unsafe. You would need to wrap them in electric tape or heat shrink tubing.
W o o f -={(
Re: bus (3.00 / 0) (#3)
by wiredwrong on Mon Mar 24, 2008 at 09:53:23 PM MST
"Using uninsulated wire/tube to make battery connections is unsafe."
I'll second that! If it gets shorted, them wires/pipes get hot, don't grab a hold with bar hands...
Randy OKC,OK
Re: bus (3.00 / 0) (#4)
by richhagen on Wed Mar 26, 2008 at 03:00:19 PM MST
I've used flattened tubing for busses before with satisfactory results.  Those busses were mounted within a steel box for solar panel connections which is still in use after over three years.  Rich
  122 Scoop users have viewed this posting.
· Also by windspeed
