Its up!!
By frackers, Section Diaries
Posted on Mon Mar 24th, 2008 at 07:08:04 AM MST
Another 10 footer flying
Well my mate Dave turned up with his trailer with the 38m (120 foot) telescope mast - only 3 sections out of the 6 of it loaded - and now I know what order to wind the winches to get the beastie up.
Our first trial is at about 9m (30') just to see how it goes. I'm impressed!!
15km/hr breeze (according to my weather station) and it immediately leap off at 8 amps so a very useful 200w into the pair of 150amp/hr truck batteries I'm using on my 24v system.
I don't have any image resizing software immediately to hand but this is the test system until I put a couple of fences across the paddock for guy anchors during the winter (the ground is too hard at present).
I'm impressed by the lack of noise - just a very faint hum.
Bugs discovered so far are:
  • a slight imbalance, not sure if its static balance (which I tried pretty hard to get right), blade tip tracking or something else
  • the angle of the tail need to be another 10 or 15 degrees - its at about 100 at present and the tail is not pulling it round into the wind very well.
  • I forgot to grease the yaw bearing on assembly so its not turning into wind at low wind speeds very well. That relates to the point above. I'd like a bit of PTFE sheet as a bearing on the pole as well as some gunge...
  • Its up!! | 12 comments (12 topical, 0 editorial)
    Re: Its up!! (3.00 / 0) (#1)
    by Janne on Mon Mar 24th, 2008 at 01:51:18 AM MST
    (User Info) http://www.anotherpower.com/gallery/janne
    Hi!
    Looking good, i like your tail :) I bet you'll have more that you can consume, when you get the rest of the tower assembled ;)
    what are the dimension on the turbine and the generator?
    contact: #tuulivoima @ircnet or #otherpower @irc.otherpower.com
    Re: Its up!! (3.00 / 0) (#2)
    by frackers (g8ecj at *nospam* gilks dot org) on Mon Mar 24th, 2008 at 03:08:59 AM MST
    Check out my previous diary entries for the last few weeks - everything is details there...
    Re: Its up!! (3.00 / 0) (#3)
    by BruceDownunder (brucedownunder@hibis.wbs.net.au) on Mon Mar 24th, 2008 at 09:58:14 AM MST
    Nice stuff ,,  are you in Oz ?
    I'm in se queensland.
    Brucedownunder
    Re: Its up!! (3.00 / 0) (#4)
    by frackers (g8ecj at *nospam* gilks dot org) on Mon Mar 24th, 2008 at 01:01:58 PM MST
    Just outside Christchurch, South Island, NZ
    Re: Its up!! (3.00 / 0) (#5)
    by jmk on Mon Mar 24th, 2008 at 05:51:35 PM MST
     Nice set up! It seems weird to me seeing Summer when I still have a foot of snow in the back yard. Have fun with it.
    jmk
    Re: Its up!! (3.00 / 0) (#6)
    by coldspot on Mon Mar 24th, 2008 at 09:46:28 PM MST
    SWEET-
     Very nice looking stuff !!!
    "image resizing software"
    "IrfanView"
    Free download, easy to use.
    $0.02
    Re: Its up!! (3.00 / 0) (#7)
    by frackers (g8ecj at *nospam* gilks dot org) on Tue Mar 25th, 2008 at 03:01:57 AM MST
    "IrfanView" = free download, Windows to run it on = $199.00
    Sorry - I don't 'do' windows
    Re: Its up!! (3.00 / 0) (#8)
    by fungus (info@reenergy.co.uk) on Tue Mar 25th, 2008 at 07:21:58 AM MST
    What are you on then?
    Most linux versions come with free editors in the bundle, I'm running ubuntu which came with GIMP , theres plenty for Mac's too.
    (PS-Christmas island? (ath.cx) :) )
    Fungus - www.reenergy.co.uk
    Re: Its up!! (3.00 / 0) (#9)
    by zeusmorg on Tue Mar 25th, 2008 at 11:39:07 AM MST
      If you're running linux, then i imagine it came packaged with GIMP which will re-size
    any graphics file. If it didn't then add GIMP. (it's also available for windows)
    Re: Its up!! (3.00 / 0) (#11)
    by frackers (g8ecj at *nospam* gilks dot org) on Tue Mar 25th, 2008 at 06:37:08 PM MST
    OK - I admit it. I have all this software to hand but since I'm already putting all the pictures onto the my own website and I find the connection to the board somewhat flakey from here sometimes I just put in a link. That has the advantage of giving readers the opportunity to see the full 5megapixel images as ell as the scaled ones.
    Sitting here at work and now that I can see the wind speed etc at home I see I'm missing some good testing weather :-(
    Re: Its up!! (3.00 / 0) (#10)
    by Old F on Tue Mar 25th, 2008 at 06:28:51 PM MST
    Watch your tail  I have seen a border collie herding clouds over a golf  course
    Also seen a whale as a tail a pig an a rooster  I like tail art
    Have fun
    Old F
    Having so much fun  it should be illegal
    Re: Its up!! (3.00 / 0) (#12)
    by frackers (g8ecj at *nospam* gilks dot org) on Wed Mar 26th, 2008 at 07:47:58 PM MST
    Still waiting for a good strong wind (isn't it always the case?) but with a 30km/hr gust last night I saw 34amps and just starting to furl (tail angle down from 100 to about 80 degrees). With the fully charged batteries I have on there sitting at 28 volts with that much charge current, that corresponds to 950w so I'm a very happy camper:-)
    Still got to make the charge controller so I'll be making a start on it tonight I hope.
      156 Scoop users have viewed this posting.
    · test system
    · frackers's Diary
