| Here are some process and final pictures of my last project.
http://picasaweb.google.com/jehmobile/WindGeneratorWoodBladesV02beta
There are captions under each picture. Feel free to ask me questions.
I started out wanting to make the blades from a single piece of wood. Mostly because I do not trust my carpentry skills enough to try to build 3 identical pieces, and THEN mount them at 120 degrees from each other.
I am NOT a wood-worker, and I was very intimidated by the project. I got the plans from someone in a PDF file, and I seriously looked over them for a YEAR trying to figure out what I was looking at. I used a hand-saw, chisel, and belt sander (with 50 grit sandpaper) to do this project. I made LOTS of mistakes - chiseling too deep, cutting over the lines, sanding too much, but they STILL WORK GREAT. And they only cost me 4 feet of a 2x6, which I bought for $5. So that's $2.50 for these, with another, uncut 4 foot section for my next project.
Well, folks, if you are intimidated like I was about working with wood, the best advice I can give is to go out, buy a 2x6, and start marking and cutting away. It all makes sense once you start doing it. And it's CHEAP.
I also had a lot of help from Windstuffnow Ed, who I'd wholeheartedly recommend as both an adviser and a vendor.
As I mentioned, I made a few mistakes. But, as I found out, this is NOT an exact science. If you are a new person, don't be intimidated by all the talk of angles, airfoils, air gaps, etc.
Those people have legitimate points - they are trying to extract every possible bit of energy out of their systems. But in practice, these wind generators are [b]very forgiving.[/b] As long as your blades are balances and slanted, they'll work. It's only a matter of HOW WELL they'll work. And that will get better as you make more of them.
I mounted this bladeset to my 40v Ametek motor, which I figured out need approx 400 rpm to get to 12 volts. I held it in my hand and saw my voltmeter peak at 15 or 16 volts in a nice, hardy wind. This was just standing in my driveway! PLEASE be careful if you hand-hold these things. If they are off-balance, the amount of shaking at 400+ RPM will literally throw them out of your hand. And the blades can seriously injure you.
Any questions, just ask! And hopefully my next project (there's always just one more) will look better than this one! But for now, these are going to be put to work. |
148 Scoop users have viewed this posting.
