uploading a bmp drawing
By blueyonder, Section Newbies
Posted on Fri Mar 07, 2008 at 10:12:04 PM MST
im not sure how to make it jpg
 ive done a drawing using paint m/s.
 but not sure if its ok to post it as i dont want my ----- chewed off.
  it is not a big drawing . but thought it might be better to ask first.
  i have checked in HOW TO USE THE BOARD. but cant find any thing.
 i dont evan know what bmp means. any help out there please.
uploading a bmp drawing | 8 comments (8 topical)
Re: uploading a bmp drawing (3.00 / 0) (#1)
by Tritium on Fri Mar 07, 2008 at 03:28:31 PM MST
Bitmap files are just about taboo due to file size.  You need to convert it to a JPG at 640 X 480 max. Photo Size is limited to 150K bytes.
Thurmond
Re: uploading a bmp drawing (3.00 / 0) (#2)
by asheets on Fri Mar 07, 2008 at 03:55:04 PM MST
Load the bmp in MSpaint, MS Office Photo Editor, GiMP, or some other handy photo editor, then select file>save as and save the file as a jpg.
_____________________________
Alan Sheets
Re: uploading a bmp drawing (3.00 / 0) (#3)
by blueyonder on Fri Mar 07, 2008 at 04:18:15 PM MST
well i thought i would have a big problem there but i have done it.
 wasent so bad.
 now i need to ask if the drawing i have done with the bits i have will work or not.
  maybe the power will go up and down to much the relay will just chatter.
  but its how i see to do this.
  maybe i would be better posting this on controls.
  can i try use this to heat water?
Re: uploading a bmp drawing (3.00 / 0) (#4)
by ghurd on Fri Mar 07, 2008 at 04:34:31 PM MST
Fine use.
I have a distaste for relays.  2 cent personal opinion.
And I have some power fets that can take the 140W each easy enough, I think.
They are 0.0045 ohms.
Cheaper than a relay too.
Back on topic, try saving a file of that type can be pretty nice as a '.gif', in a very small size.
Check my files for gifs and their sizes.
Ghurd.info
Re: uploading a bmp drawing (3.00 / 0) (#5)
by kurt on Fri Mar 07, 2008 at 06:42:57 PM MST
three cheers for blueyonder for having horse sense. and i usually convert bitmaps to .gif format it is done the exact same way you converted that one except you select .gif instead of .jpg convention says .gif for drawings .jpeg for pictures.
IRC inst.
Re: uploading a bmp drawing (3.00 / 0) (#6)
by feral air on Sat Mar 08, 2008 at 01:40:54 PM MST
That image is only 44KB. Converting it to a .gif of the same quality brings it down to about 25KB - not quite in half, but pretty close. A low quality .gif version would probably be fine and be smaller still.
You might want to check out Easily resize images for this site and Resizing Photos Made Easy too. For future reference. :)
take it easy
Re: uploading a bmp drawing (3.00 / 0) (#7)
by blueyonder on Sun Mar 09, 2008 at 07:20:46 AM MST
 thanks guys for the help.
  in the past when i clicked save as. i normally just gave it a name (typed)
  but now i had to look at converting it.
 so i clicked on the other bit below. a drop down menu came out .
 and hay presto it had all the different things i needed .
 so now i understand how to make it jpeg or gif  .just select then save.
  i hope the horse isent upset by kurt saying i have horse sence.
  thanks ghurd . so yes fine means i can start playing with this setup .
    ghurd you say you have sum power fets . if thay use power fets in the space shuttle
  then i am lost.
  i will do a search to find the p/fets . and if there simple to fit.
 will take relay out and fit.
  but yes i do have one of your controllers here in the uk.
   this is a world wide thing you got going here ghurd.
   my one came via scotland.   later i will put a story on water heating and post a few pics of how it all looks.
   thanks yeh all.
Re: uploading a bmp drawing (3.00 / 0) (#8)
by ghurd on Sun Mar 09, 2008 at 08:41:57 AM MST
I just noticed something.
The negative wire of the relay should go straight back to the battery negative, not share the negative with the controller.
Not sure how the relay coil is powered, but that could cause some problems too.
You have mail.
Ghurd.info
  63 Scoop users have viewed this posting.
· Also by blueyonder
