Jacobs variable pitch
By cdog, Section Mechanical
Posted on Fri Mar 07, 2008 at 02:22:00 AM MST
Anyone have any pics or links?
Hello guys, I have been looking for the Jacobs variable pitch mechanisim that works with the weights. I can seem to find lots about the spring type governors, but very little about the flyball??type.
Just wondering if anyone had any info, thanks as always,
Cdog.
Jacobs variable pitch | 4 comments (4 topical)
Re: Jacobs variable pitch (3.00 / 0) (#1)
by WXYZCIENCE on Thu Mar 06, 2008 at 07:41:08 PM MST
Cdog, I was working on hubs and someone posted a pic of Jacobs hub on my post.
http://www.fieldlines.com/story/2006/5/8/214511/7630
Joseph.
Re: Jacobs variable pitch (3.00 / 0) (#3)
by wdyasq on Thu Mar 06, 2008 at 07:48:46 PM MST
A bit of information here:
http://www.anotherpower.com/gallery/Variable-Pitch
Re: Jacobs variable pitch (3.00 / 0) (#4)
by cdog on Thu Mar 06, 2008 at 08:39:45 PM MST
Thanks guys, I was thinking of making something similar, but using one ring gear and 3 pinion gears fron a quarter ton rearend. Is there any way to even come close to determining how much weight and mechanical advantage one needs to handle the blades? I was thinking of spinning the whole assembly in the lathe to watch it work, but how will having the blades attached affect how it works?
Cdog.
Re: Jacobs variable pitch (3.00 / 0) (#5)
by Flux on Fri Mar 07, 2008 at 12:22:48 AM MST
You can basically calculate the operating speed from the mass of the weights and the spring rate. Force on the revolving mass is m.r.(omega^2)
You can run the hub in a lathe. The blades will have some effect unless they rotate about the centre of pressure. How much effect this will have depends on the relative forces acting to twist the blade compared with the spring preload.
You get best control with lots of spring preload and heavy weights but there can be some compromise to keep the weight to reasonable proportions.
Similarly the more friction ( maybe more accurate to say stiction)you have the greater mass and preload you need.
  143 Scoop users have viewed this posting.
· Also by cdog
