| Hi all,
In a previous post about absorber plates in flat plate collectors, Gary pointed to a link on his site
http://www.builditsolar.com/Projects/SpaceHeating/SolarShed/Tank/Tank.htm
for a homemade wooden storage tank that seems very easy and cheap. Do I understand it right that the fact that the tanks are not pressurized has the consequence that water in the tank is not to be used in any piping but just for storing heat within the tank? That would mean that if I want to use such a tank for solar water and space heating (in NB, Canada), there would need to be three heat exchanger coils in the tank: one for circulating heat transfer fluid to and from the solar collectors, one to circulate water to and from the radiant floor tubing and one to circulate water to and from the back up electric water heater.
I suspect that the third heat exchanger coil would need to be pretty large because it would be used less continuously and would need to store some heat inside the tubing. Would this coil need a pump to circulate to the electric back up water tank or be used
Is this the way you think this type of tank could be used?
Anyone having a flow diagram using such a tank, could you please post it?
Thanks for your help
Martin
Eau, soleil, le vent |
122 Scoop users have viewed this posting.
