yet another vawt rotor in progress part one
By Stonebrain, Section Diaries
Posted on Wed Apr 16, 2008 at 09:50:25 PM MST
lots of pics
Where to start...The materials.
Yes,that's right,greengrocers crates.Absolutely FREE.
Maybe some of you reading this magic word are running to the greengrocer allready,but warning:this is a lot of work! No such thing as a free lunch.
Well never mind,this is great stuff for lighting the fire too.
Carefully taking off the planchettes,a knowhow by it's own.
Then sawing them to uniform strips(I did it on my small bandsaw),mostly 35mm for me.
They are mostly with rusty holes of nails,cracks,and nots.
The planchettes are mostly 2mm(2/25") and 4mm(4/25").They are in poplar(majority)and pine.These details are for France and may depend on local conditions.
I only used the poplar allthough they are very warped compared to the pine.I think ppoplar is superiour for this purpose,there must be a reason poplar was widely used in early aircraft construction.Light,soft,but strong(and cheap).Used in lamination,the warping is not a point.
This is the yield of 3 or 4 crates.Great basic material.I didn't use much of the 2mm this is more work and cost more glue. A shame there is not much of 6mm or more available.
This is the expensif stuff.The 13.30 Euro is for 500 gram.I used about a half of these flacon for what you get in this diary.I have a love-hate relation with this stuff.By principle I hate chemical stuff,but I don't know about anything comparable for wood.It is very water resistant and strong with an axcellent adhesion.
It's foaming and fills up small cavities and cracks.
Here you see the foam coming out of laminates.
I started gluing together some,
Then it started growing,layer by layer,a bit like a tree.
Allways lots of clamps
vertical arms for the future airfoils in progress
Then I realised I needed a hub
I made it fit in the center,then machined the two surfaces.
This was my first mistake.The hub was were I should have started˙Ishould have machined it on  the circonference,and then start the rotor fitted on the hub.
Never mind it is not that bad.
some finishing.
Well,sofar
cheers,
Jaap
yet another vawt rotor in progress part one | 11 comments (11 topical)
Re: yet another vawt rotor in progress part one (3.00 / 0) (#1)
by tecker on Wed Apr 16, 2008 at 04:41:47 PM MST
Impressive I can smell the urethane from here It kinda gets under your fingernails and gets looks at the dinner table.
Re: yet another vawt rotor in progress part one (3.00 / 0) (#10)
by Stonebrain on Thu Apr 17, 2008 at 03:09:48 PM MST
I see,you've been through it too.
Re: yet another vawt rotor in progress part one (3.00 / 0) (#2)
by vawtman on Wed Apr 16, 2008 at 05:19:38 PM MST
Hi Stonebrain
 You got quite the project going on there.I used a product called Gorrila Ultimate in the US on my wooden test stator that the wife broke.It wasn't the glues fault i just had too many holes drilled in it. :)
 Does yours require a dampening with water to get going?Strong stuff indeed.
Re: yet another vawt rotor in progress part one (3.00 / 0) (#8)
by Stonebrain on Thu Apr 17, 2008 at 03:04:56 PM MST
If the wood is really dry,some extra humidity can help to make it foam.
touching the wood with a slightly humid cloth is enough.
Re: yet another vawt rotor in progress part one (3.00 / 0) (#3)
by WXYZCIENCE on Wed Apr 16, 2008 at 09:53:40 PM MST
Stonebrain, the vawt artist at work again. Real good pictures also.
Joseph
Re: yet another vawt rotor in progress part one (3.00 / 0) (#4)
by ZooT on Thu Apr 17, 2008 at 12:35:42 AM MST
I really like those laminations......seriously....structural plywood engineered for a specific purpose.....yeah....I "really" like that..........
Re: yet another vawt rotor in progress part one (3.00 / 0) (#5)
by Capt Slog on Thu Apr 17, 2008 at 05:34:14 AM MST
That looks great.  I too love those lamination and how they come togetehr in the centre.  I can't help thinking that this would be a good  (if tedious) way to build a HAWT prop to get good strength at the hub.
Re: yet another vawt rotor in progress part one (3.00 / 0) (#6)
by Dave B on Thu Apr 17, 2008 at 10:52:31 AM MST
This is really great work and in the true spirit of the board. Thanks for sharing and keep us updated.  Dave B.
Re: yet another vawt rotor in progress part one (3.00 / 0) (#7)
by asheets on Thu Apr 17, 2008 at 02:06:16 PM MST
I was thinking the same thing...
_____________________________
Alan Sheets
Re: yet another vawt rotor in progress part one (3.00 / 0) (#9)
by Stonebrain on Thu Apr 17, 2008 at 03:07:17 PM MST
Thanks for the encouragements everyone.
cheers,
Jaap
Re: yet another vawt rotor in progress part one (3.00 / 0) (#11)
by jmk on Sat Apr 19, 2008 at 08:39:33 PM MST
 Wow! What a project. Your going to have some time rapped up in this one. It's looking good. Thanks for the pictures too. It reminds me of building the balsam wood airplanes. By the time you have them done you don't want to fly them.
jmk
  148 Scoop users have viewed this posting.
· Stonebrain's Diary
