Where Can I Obtain These Battery Connectors?
By Slingshot, Section Storage
Posted on Fri Apr 18th, 2008 at 08:08:09 PM MST
Looking for a surplus or inexpensive source
Shown below is the battery connection of a 28-AH, 24-V sealed aircraft battery.  I have several of these surplus batteries that I've pulse-desulphated/charged, and would like to use them in a solar/wind application.
What I need is an inexpensive source of mating connectors.  I've been using large alligator clips for charging and experimentation, but would like to have a cleaner arrangement for permanent installation into a renewable-powered workshop and Ham shack.
Where Can I Obtain These Battery Connectors? | 14 comments (14 topical, 0 editorial)
Re: Where Can I Obtain These Battery Connectors? (3.00 / 0) (#1)
by wiredwrong on Fri Apr 18th, 2008 at 02:51:51 PM MST
I pretty sure the connector is called a "MS-3509" try an airplane salvage yard.
Randy OKC,OK
Re: Where Can I Obtain These Battery Connectors? (3.00 / 0) (#6)
by brightmae on Sat Apr 19th, 2008 at 12:36:40 AM MST
(User Info) http://brightmae.gaia.com/blog
do you have a photo?
please send to my email morr278@gmail.com
I will check it for you.
www.ahpaiya.com MSn:xuping_huahua@hotmail.com email:morr278@gmail.com
Re: Where Can I Obtain These Battery Connectors? (3.00 / 0) (#2)
by Dozzer7 on Fri Apr 18th, 2008 at 02:54:04 PM MST
I might be able to round up a few old ones from the scrap pile that would still be usable for non aircraft use. Drop me a line with your address. S64F-at-MSN.com is mine
Re: Where Can I Obtain These Battery Connectors? (3.00 / 0) (#11)
by Slingshot on Mon Apr 21st, 2008 at 09:30:43 AM MST
Sending email now, thanks.
Re: Where Can I Obtain These Battery Connectors? (3.00 / 0) (#3)
by zeusmorg on Fri Apr 18th, 2008 at 03:07:05 PM MST
 Buying that particular connector new would be more than replacing the battery  with a comparable deep discharge lead acid set, so I'd try some of your local airplane mechanics to see if they can salvage some old ones, or make your own.
Re: Where Can I Obtain These Battery Connectors? (3.00 / 0) (#4)
by nick1234 on Fri Apr 18th, 2008 at 07:38:21 PM MST
if you do not find the connector and in a hurry you could make some with some thick wall brass tube drill to size cut a X at the end to a depth greater than the length of the post squish in for tight fit put a peace rubber hose  for insulation  connect wire at other end
enjoy
nick1234
Re: Where Can I Obtain These Battery Connectors? (3.00 / 0) (#5)
by Jerry on Fri Apr 18th, 2008 at 10:41:12 PM MST
Hi Slingshot.
I drilled and taped mine for 1/4-20 threds. I used a brass washer between the copper bus barr.
The bar is held to the battery post with 1/2" long 1/4- 20 brass bolts. This has been working great now for several years.
This is a 48 volt system.
Airheads Page
Re: Where Can I Obtain These Battery Connectors? (3.00 / 0) (#7)
by Spaz (jraba@mass.rr.com) on Sat Apr 19th, 2008 at 08:57:33 PM MST
(User Info) http://crosscountrycommercialflooring.com
i think i saw a connector for that on EVparts.com I don't remember the price
Re: Where Can I Obtain These Battery Connectors? (3.00 / 0) (#8)
by mbeland on Mon Apr 21st, 2008 at 08:34:23 AM MST
Pretty neat set up! Do I understand well, they are sealed so it means you don't have to water them up so that's why you can pile them up that way?
Martin
Eau, soleil, le vent
Re: Where Can I Obtain These Battery Connectors? (3.00 / 0) (#9)
by Slingshot on Mon Apr 21st, 2008 at 09:28:22 AM MST
Jerry,
I assume this means that the terminal posts are solid, not hollow?
Re: Where Can I Obtain These Battery Connectors? (3.00 / 0) (#13)
by Jerry on Tue Apr 22nd, 2008 at 09:14:05 PM MST
Hi Slingshot.
Yep they are solid not hollow.
Airheads Page
Re: Where Can I Obtain These Battery Connectors? (3.00 / 0) (#10)
by Slingshot on Mon Apr 21st, 2008 at 09:30:12 AM MST
Thanks, I was thinking about that also, because the terminals reminded me of the connection posts on my crackerbox welder.
Re: Where Can I Obtain These Battery Connectors? (3.00 / 0) (#12)
by yuandrew (yu(dot)andrew(at)yahoo.com) on Tue Apr 22nd, 2008 at 02:18:57 AM MST
They could be an "Anderson" type connector. Look around on www.andersonpower.com
Anderson power products makes many specialized high current connectors; chances are good that they would have something like that.
"Always under construction"
Re: Where Can I Obtain These Battery Connectors? (3.00 / 0) (#14)
by dnix71 (yahoo.com 'dnix71') on Sun May 11th, 2008 at 02:03:37 PM MST
My Curry eBike has receivers for the battery pack like that, but the pins are only 1 inch apart.
  184 Scoop users have viewed this posting.
· Also by Slingshot
