baby PMA
By commanda, Section Diaries
Posted on Wed Apr 30th, 2008 at 03:55:02 AM MST
for a Lenz2 with rim drive
So I salvaged some steel rotors from the plasma cutter offcuts at work.
105mm dia by 8mm thick.
Each rotor has 6 magnets, 20mm dia by 10mm high N45.
The coils will be 5 of (5 phase). Each phase individually rectified then wired in series for a 24 volt system.
Not visible in this first photo, but at the center of each potted magnet rotor is a 16mm nut welded to the rotor.
The 3rd rotor holds the solid rubber tire. This will run against the circular plywood baseplate of the Lenz2.
A quick test with a 12 turn test coil gave 0.1 volts ac at 195 rpm. From this I figure approx 350 turns per coil (0.5 or 0.6mm wire) for a cutin of 300rpm, and approx 45 watts at 600 rpm (0.5mm wire). Will do a better test coil before proceeding.
The air gap is 12mm. Stator will be 10mm thick and each coil cross-section will be 10mm by 10mm. Sideways gap between magnets is just over 20mm.
If the Lenz2 is 2 foot diameter, with a TSR of 1, wind at 10Km/Hr (2.7 m/s) should give 88 rpm. The 5inch dia rubber tire will give a gear-up of approx 5:1, giving an alternator rpm of 440rpm.
baby PMA | 4 comments (4 topical, 0 editorial)
Re: baby PMA (3.00 / 0) (#1)
by gotwind2 (ben[at]gotwind.org) on Wed Apr 30th, 2008 at 02:17:31 AM MST
(User Info) http://www.gotwind.org/index.htm
I love the idea and will follow  further comments with interest.
My thoughts:
The coils may be tricky to wind/fit at such a size?
Stator might get pretty hot without a good cooling design?
Frictional losses with rubber tyre drive, maybe you could also experiment with a 3 to 4 foot diameter propeller as a HAWT also(directly driven).
I hope it works.
Good luck
Ben.
www.gotwind.org
Re: baby PMA (3.00 / 0) (#2)
by blueyonder (windwoodgood at yahoo dot co dot uk) on Wed Apr 30th, 2008 at 05:20:34 AM MST
  its interesting i must say.
 it will be like the old type bottle dynamo that rubs on a bike wheel.
  thats why gotwind is so interested .
 i will also be fallowing it with interest .
  just think you could fit it to a motor bike wheel to keep you going if the motor
 bike gen failed . i mean a 12 volt one.
  good idea for a dessert island .
Re: baby PMA (3.00 / 0) (#3)
by tecker on Wed Apr 30th, 2008 at 06:35:44 AM MST
I've used threaded rod and the way I got it to run true was to mill nut faces install them bearing to bearing .
Re: baby PMA (3.00 / 0) (#4)
by gotwind2 (ben[at]gotwind.org) on Wed Apr 30th, 2008 at 01:30:16 PM MST
I was hoping for more thoughts/ideas on this interesting (to me at least) project.
'Flux' amongst all the other experts.
Ben.
www.gotwind.org
  170 Scoop users have viewed this posting.
· commanda's Diary
