The free Garbogen stators.
By Jerry, Section Classifieds
Posted on Fri Apr 4th, 2008 at 04:00:54 AM MST
More info.
 Some of these stators are a littel crusty rusty on the inside. The stators are fairly clean its just the inside of some of the cans that could use some sandpaper or steel wool.
The stators are not centered in the can. I'll drill out the position dimples on most and push the stator closer to but not centered. You will center the stators in the cans.
Your going to take the stator out of the cans to rewire anyway. That way if there is any can cleaning to be done it can be done then.
I'll give you the Pay Pay address in a e-mail. I checked with the Post Office today.
They still have the  $8.95 Flat Rate box. If you don't mind I would like $10 per Flat Rate box. This will offset my time and gas a littel. I hope thats not out of line?
So you send me $10 and I send you a Garbogen stator in a Flate Rate box while they and me last.
Some times things get crazy at my store so bare with me.
The free Garbogen stators. | 8 comments (8 topical, 0 editorial)
Re: The free Garbogen stators. (3.00 / 0) (#1)
by TomW on Thu Apr 3rd, 2008 at 10:10:50 PM MST
Jerry;
Sounds pretty fair to me. I know you won't get rich on this.
Re: The free Garbogen stators. (3.00 / 0) (#2)
by ZooT on Thu Apr 3rd, 2008 at 11:08:58 PM MST
LoL
Heck Tom......if he does get rich making a whole $1.05 on each garbogen stator, then I'd say that first off he's earned it.......and second off......that he had WAY too many garbogen stators floating around 8^P
Re: The free Garbogen stators. (3.00 / 0) (#4)
by ghurd on Fri Apr 4th, 2008 at 05:41:35 AM MST
PayPal will take about 50 cents, leaving 55 cents for bubble wrap, tape and peanuts.
Won't be enough extra for gas scented fumes.
Re: The free Garbogen stators. (3.00 / 0) (#3)
by Old F on Fri Apr 4th, 2008 at 05:23:57 AM MST
I  would say 20 bucks would not be to out of line .
One stator 10 bucks
Tec support an questions answered an past research 10 bucks
Fun building your own garbogen priceless  : )
Old F
Re: The free Garbogen stators. (3.00 / 0) (#5)
by Bruce S (bruce(dot)stahl <at>gmail (dot)(com)) on Fri Apr 4th, 2008 at 06:54:41 AM MST
I'm with Old F.
I was thinking it would be up in the $20 range too.
Will be a great project going into summer. Sitting on the patio, sipping sun tea, sanding rust :-) I like it!!
Jerry, been reading up on your past posts, lots of good info in there too.
Many Thanks for such a great offer.
Re: The free Garbogen stators. (3.00 / 0) (#6)
by yakas on Fri Apr 4th, 2008 at 10:47:17 AM MST
(User Info) www.pixelknapper.com
What is a garbogen stator?
If it's 10 bucks it could be used as a good example of how they should be made. For guys like me who don't even know what it is.
Re: The free Garbogen stators. (3.00 / 0) (#7)
by coldspot on Fri Apr 4th, 2008 at 03:12:58 PM MST
yakas-
"garbogen"
 type that into either search, google works better but the other one works fine also.
 That will learn you about it and using the search.
$0.02
Re: The free Garbogen stators. (3.00 / 0) (#8)
by ghurd on Fri Apr 4th, 2008 at 03:39:56 PM MST
Like he said.
Most places... $20 in gas, labor, and a lot of luck, will yeild something that smokes an Air-X.
Less luck, smarter thinking, and a bit more gas will still smoke an Air-X.
Crappy luck, labor, PVC, and hard drive neos will still smoke an Air-X.  Most places.
At least here.
  195 Scoop users have viewed this posting.
· Also by Jerry
