| In an earlier post asking about how large a magnet rotor can be used on a small 6' machine, Flux wrote,
"Dual rotors about 10" diameter with 8 magnets per rotor of the 2 x 1 x 1/2 or metric 46 x 30 x 10mm will meet this requirement very adequately with a stator about 1/2" thick."
Now, after reading through posts about coil/ magnet relationship I saw several times where someone wrote that one leg of a coil should be moving over one magnet just as the opposite leg of the coil is moving off the magnet before. There is no way this will happen with the above design. Flux can't be wrong so...
If the disc is 10" and uses 2" long magnets, then the disc circumfrence at the bottom of the magnets (8" diameter) is about 25". Dividing 25" by 8 magnets gives me a little over 2" between magnets. So if the coil is 1" wide in the center open part and each leg is 1/2" wide then the outside width of the coil is 2" and it will never straddle 2 magnets at one time.
All this is given a stator with 6 coils/ 3 phase.
What is it I still don't understand? Is it ok if the coils don't straddle 2 magnets at once? Should I make the legs of the coils wider, say 1" ? I thought a rule of thumb was for one leg of a coil to be 1/2 the width of the magnet max. but maybe not.
I swear this is my last dumb coil question. No really, it is. No really I mean it.
147 Scoop users have viewed this posting.
