| I have (3) 24 volt/40AH lead acid aircraft sealed batteries. I get 1 or 2 of them per year from our fleet. They perform well and seem to last quite a while.
In any case, I would like to purchase a pure sine wave inverter and power it with the batteries. It is likely I would charge the batteries with solar panels (less than 200W). It would ALSO be nice to use 120V home power to charge (such as from the gen set) and for this unit to function as a UPS powering the fridge/freezer, TV and computers. I suppose it would be OK to use the inverter full time and simply charge the battery to cover the load. Not trying to run much with the inverter. My current 1500W will do the job.
What inverter do you suggest?
Inverter, Charge control and most electronics questions go under "Controls" so I put this in the proper section. If we ever get a board upgrade, I hope we add a section on product reviews.
169 Scoop users have viewed this posting.
