| I joined the alt and the prime driver test motor today. I did a few voltage test to confirm proper output for both star and "Jerry Rigged".
The #s are right on where they should be. Now I can add the fullwave bridge rectifiers and continue with all the other testing.
Here are a few pictures. First I brought the rpm up till the ac voltage per coil is 5v.
These are no load tests. Next I configured the alt star. Star produce 17.2 volts between any 2 connection of 3 phase.
"Jerry Rigged" produced 20 volts on any one of the phases.
Here are the pictures.
 This is the 5 volt 1 coil.
This is the star reading.
This is the "Jerry Rigged" reading.
OK, Testing continues.
JK TAS Jerry |
110 Scoop users have viewed this posting.
