| My project is a delco 10si with windblue pm rotor. My tests include 3 stators, one 63amp one 37amp and one special wound low wind stator from windblue.
First test
- amp stator
- 67v dc @400 rpm
- 53v dc @1200 rpm
- amp stator
- 0v dc @400 rpm
- +v dc @1200 rpm
- 0v ac @400 rpm (from each of 3 phases)
- 1v ac @1200 rpm (from each of 3 phases)
windblue low wind stator
(tester overloads @20+ dc volts)
20+ v dc way before my cordless drill is close to 400 rpm
I cant even test dc @1200 rpm, way too much
- 3v ac @400 rpm (from each of 3 phases)
- 0 v ac @1200 rpm (from each of 3 phases)
Im turning alternator by my cordless drill which has 2 speeds, 400 & 1200 rpm. Each test was run with fresh charged drill battery so all tests started with the same devise at the same charge turning the alternator.
I priced magnets, wire and all the stuff to try to assemble my own alternator but found I was better off letting those who "know" build em. I have nothing lying around I could say "I built this from scraps" so I bought it ALL! That being, the rotor and stator from windblue. Im tickled at the results so far.
Comments disabled on original posters request.
