| A month ago I fitted a set of wooden blades to my turbine, and thought that this would give me the power that the thing is capable of producing. So far though I've been disappointed.
Just to recap...dual rotor, 12 mags on each, each magnet is N45 1 inch diameter by 3/8 inch high, air gap around 13mm, 9 coils, 60 turns each, 16swg wire. Cut in is around 275 rpm. Goes to 12v batteries via a line resistance (a few ohms, sorry, can't remember the number, but it's 5 or less)
The wooden blades I made are around 7 tsr, and 25 inches long, set of three. It spins really easily in the lightest of breeze. Unfortunately, it never seems to get particularly quick, even though it does get quite windy at times. I'm beginning to wonder if it will ever get enough wind to be effective, which is a shame.
I'm wondering now about putting back PVC but also........
reducing the diameter, (so that I will get more rpm?)
Use narrower blades but put on 6 of them to give more solidity.
I realise that there will be a serious stall issue with lowering the diameter but I can adjust the line resistance to cope.
I'm figuring it will be better to be producing 1/2 amp a lot of the time rather than nothing for most of the time because I never get to cut in. |
156 Scoop users have viewed this posting.
