| first i will attempt to lay out the parameters
assume we are talking about a single pole of a laminated core stator
much like any other alternator such as automotive, genset etc.
the voltage drop in the stator is due (in part) to the reactance of the stator and current in the stator,, more current, higher frequency, and higher inductance of the pole coil all work to drop voltage.
so now the question
what if one were to wind two coils on the same pole, each to be seperately rectified
so they do not have circulating currents between them which would cancel each other out.
with two coils wound bifilar as per example, it would seem they would both produce power, but the effective inductance would cancel?
i can reduce the current by raising the voltage, i can reduce the frequency by turning slower, but the only way i can reduce the inductance of the coil is by reduceing turn count (which would make raising voltage impossible without increasing speed which would increase frequency)
so can a bifilar wound pole exhibit theoretically zero inductance and still produce power if the two coils are kept seperate and rectified seperately?
(on a typical 3 phase alternator we end up with 6phases of course)
if not why not?
would the leakage inductance work to cancel each coil because they are 180 apart?
bob g |
135 Scoop users have viewed this posting.
