| I have a small 5 watt PV charging 12v 5 amp/hr batteries. I have a 1200 watt HF inverter connected to several of the batteries in parallel. Using a digital volt meter, I can't seem to get an accurate battery volt reading, because apparently the inverter holds a charge. I have to unplug the inverter, to get correct readings.
I don't have any charge controler as of yet. Is there a simple way to do this?
Can I put a diode between the battery and inverter or something? |
72 Scoop users have viewed this posting.
