| So we have several remote sites that are battery powered and after fighting dump loads and etc I was struck with an idea. Thought I'd run it by the people here and see if this was a possible way to eliminate the headaches.
If a person were to take apart a 10si style alternator and replace the stator with a fine wound stator like the DC540 from Wind Blue, could you retain the internal regulator and rotor to provide a regulated output but start charging at lower speeds like a PMA? Basically, it would be a standard alternator with a fine stator, so the question is, would it work similar to a PMA as far as the power curve? We had a DC 520 PMA running at one site and it worked great other than the fact we were always fighting with having excess power and dump loads and and and... My thought was leave the internal regulator and when the battery voltage gets up to whatever the regulator voltage is set at, it quits exciting itself just like in a car.
I am well aware that it won't be efficient, won't be ideal, etc... But we are looking for a simple solution to mass deploy and not have to fight diversion loads in wind systems. Input would be appreciated. |
138 Scoop users have viewed this posting.
