Read here (fieldlines) about about using concrete, (Alumina Trihydrate) ATH and others.
No references to using Aluminum Oxide on searches here.
Materials properties:
http://www.engineeringtoolbox.com/thermal-conductivity-d_429.html
Notice epoxy 0.35, Mortar cement 1.7, Portland cement 0.29 yuck, Iron 80.
Ideal Material must be Non conductive, cheap, and available.
Consider: Aluminum Oxide (alumina or aloxite)
http://en.wikipedia.org/wiki/Aluminium_oxide
Thermal conductivity 30-40 (depending on reference) and is non-conductive!
Melting point 2054 °C, low cost and available as sand blasting abrasive.
How to use?
The Aluminum Oxide grains must be touching each other to transfer the heat, consider using a very thin epoxy mixing in Aluminum Oxide to produce a thick paste.
Consider ridges in the stator structure to increase surface area to cool better.
Guessing at this point but 5-10 thermal conductivity should be achievable?
Anybody try this?
Cautions:
Aluminum Oxide is bad to breath, just ask NTL.
Aluminum Oxide is very hard, with a stator made of it, expect magnets to be ground up if they touch, magnets are hard also, not sure which is harder.
Benefits
Cooler running stator, lower cost stator, stronger stator structure.
Not seeing any down sides.
Comments?
Have fun,
Scott. |
