Sealed Lead Acid Batteries
By David HK, Section Storage
Posted on Sat May 17th, 2008 at 11:24:50 AM MST
What you buy
Ladies and Gentlemen,
If I pop into a shop to purchase some sealed lead acid batteries that are rated at 12 volts 7 ampere hours, and ask to place a pair of prongs from a digital multi-meter over the contacts, what voltage should I expect to observe?
David HK
Sealed Lead Acid Batteries | 2 comments (2 topical, 0 editorial)
Re: Sealed Lead Acid Batteries (3.00 / 0) (#1)
by DamonHD (d@hd.org) on Sat May 17th, 2008 at 05:50:39 AM MST
Over 12V: see 'at rest' column in chart here...
http://solarjohn.blogspot.com/2007/03/measuring-battery-state-of-charge.html
Re: Sealed Lead Acid Batteries (3.00 / 0) (#2)
by Simen on Sat May 17th, 2008 at 01:54:34 PM MST
(User Info) http://www.mwlmf.net
Practical chart, DamonHD... :) Gives one an idea of the state at a glance...
My experience with sealed lead-acid batteries are that fully charged, they have a 'at rest' voltage at around 13.00v when they're healthy.
When buying a new one in a shop, it would depend on how long the battery has been stored in the shop without any charging. According to the spec. sheet for one of mine 12v, 7.2Ah, the selfdischarge are at 92% after 1 month, 90% after 3 month, and 80% after 6 month. (All at 20deg. C.)
  107 Scoop users have viewed this posting.
· Also by David HK
