I changed the Front Page Poll question
The old question was asking What is your System Voltage, the Results with Comments can be seen here
http://www.fieldlines.com/poll/1208823889_wZykrztZ
The New Question is How are you Making Power ?
The Poll Section is Not on this page, but you can make comments.
It appears on the righthand side of the "Main Page" (Use your Back button), at the bottom of the Info areas on that side. You must have "Polls" enabled to be able to see them. If you don't see the Polls section then enable them this way...
On the right side of this page find the Menu Box with your Username on it.
Inside that box click the menu item for "Display Preferences"
At the bottom of that page is a listing for "Boxes"
Make sure the "Poll" box is Checked
The front page Poll will now display on all your Main pages.
Helpful Tip:
While you are in "Display Preferences" you should set
"Number of story summaries to show" to 50
"Number of story titles to show" also to 50
This makes the Forum easier to use because 50 story titles will display on the Main Pages instead of only 8 which is the default for new users.
133 Scoop users have viewed this posting.
